Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: My New Screen and can get more.
  1. #11
    Low Bitrate 2000Jeep's Avatar
    Mar 2006
    Standing by for pics
  2. #12
    Variable Bitrate LanoX's Avatar
    Aug 2004
    Sydney
    sorry been busy i will take a video very soon just work has been keeping me busy but i will get aroun to it 2 day or 2 morrow
    [|||||-----] 95% complete
  3. #13
    Mar 2006
    I can relate to that
  4. #14
    Raw Wave tj!2k4's Avatar
    Oct 2004
    and manufacturer/model/specs would be nice too.
  5. #15
    Low Bitrate Epon's Avatar
    Oct 2005
    opperating voltage?
  6. #16
    Oct 2004
    SoCal
    Info
    Since the OP hasn't provided the info, I'd thought I would help. It's the same brand of the K301 that MP3CAR sells.
    Model No.: K90
    Specifications:
    1) In-dash type fully motorized TFT LCD
    2) With 7" Panasonic EDTCB23QEF digital TFT LCD
    3) Diagonal size 16:9 and 4:3 adjustable
    4) 4 wires resistive touch screen panel (USB)
    5) VGA input (15 pin D-SUB)
    6) Video input system NTSC / PAL / SECAM auto switching
    7) Built-in TV tuner
    8) 2 RCA video inputs, 1RCA reverse video input
    9) High resolution display- up to 1,600 x 1,200
    10) Upgraded high-brightness CCFL
    11) Adjustable color, contrast, brightness, hue, sharpness
    12) Full-function infrared remote control, master control
    13) Screen size: 7inches / 18cm (16:9)
    14) Contrast ratio: 150
    15) LCD brightness: 400cd/sqm
    16) Resolution (pixel): 800 (W) x 3 (RGB) x 480 (H)
    17) Supported resolution: 640 x 480 - 1,600 x 1200
    18) Master dimensions (W x D x H): 178 x 155 x 50 mm
    19) Touch screen interface: USB port
    20) Operating voltage: 10.6 to14V DC
    21) Max power: 1.5A
    22) Vertical viewing angle
    a) Up: 45 degrees
    b) Down: 80 degrees
    23) Horizontal viewing angle
    a) Left: 80 degrees
    b) Right: 80 degrees
  7. #17
    Aug 2004
    Sydney
    Yes you are right those are the correctc specs of the screen and the screen is called K90 the only difference from K301 is that K90 screen slides out from the bottom and not top..
  8. #18
    Aug 2004
    Sydney
    Yes you are right those are the correct specs of the screen and the screen is called K90 the only difference from K301 is that K90 screen slides out from the bottom and not top..
    Video is coming 2 day 100% as i finish work early.
  9. #19
    Aug 2004
    Sydney
  10. #20
    Oct 2004
    why did you post that 3x?
  1. Can I remove/change the welcome screen in windows xp?
    By MeanGT in forum Software & Software Development
    Last Post: 04-07-2008, 12:55 PM
  2. Can anybody sketch DSCustoms screen mechanism?
    By nxt125 in forum General Hardware Discussion
    Last Post: 08-08-2002, 07:04 AM
  3. Can i see tv in Redant 7 screen?
    By agimur in forum LCD/Display
    Last Post: 03-15-2002, 06:00 PM
  4. Can someone point me to a good LCD screen
    By jmhenry5150 in forum LCD/Display
    Last Post: 02-10-2002, 12:58 PM
  5. Can this LCD screen be hooked up to a computer??
    By brandondere in forum General Hardware Discussion
    Last Post: 03-10-2001, 05:01 PM
