Page 5 of 11 FirstFirst 1234567891011 LastLast
Results 41 to 50 of 110
Thread: LiquidVideo LVM701 DIN Connector?
  1. #41
    May 2006
    Muncie, Home of the 4 Speed
    So, they fit in the DIN hole perfectly flush? And this can transfer the audio and video from the player to the screen?
  2. #42
    Maximum Bitrate Sidewalksalvage's Avatar
    Mar 2006
    NJ/RI
    Yep, according to the pin out, thats exactly what the DIN is used for. and it should fit flush enough to work properly
    Brown 2010
  3. #43
    Newbie BIGVANGUY's Avatar
    Apr 2006
    Ontario, Canada
    By flush, I'm hoping you mean the moulding of the plug is touching or almost touching the recepticle the same distance all the way around. i.e. The plug should eminate from the surface of the recepticle exactly perpendicular. If thats flush to you, then yes. And yes S.S. is also correct on the input, I have made cords for both inputs on mine (DVD and XBOX). But the XBOX only goes with us on long trips so I have that cord plugged into input 2. This monitor doesn't have a memory, so when you turn it off and then on, it will always come up on input 1.
  4. #44
    May 2006
    Sounds good..how much did u want for those 2 cords?
  5. #45
    Apr 2006
    Ontario, Canada
    I originaly stated $5, but I suppose I will take $4, plus shipping.
    Do NOT post your address here.
    P.M. me instead so I can give you a ship quote.
  6. #46
    Mar 2006
    NJ/RI
    Good plan HAndle any an all transactions via email or pm....you never know when a spammer is watching....
    Brown 2010
  7. #47
    May 2006
    PM sent
  8. #48
    May 2006
    Anyone? Anyone here?
  9. #49
    Mar 2006
    NJ/RI
    Quote Originally Posted by shsrebel2003
    what do you mean?
    Brown 2010
  10. #50
    May 2006
    I never got a reply from Big Van!
  1. Replacing connector in Lilliput
    By Chairboy in forum LCD/Display
    Last Post: 05-04-2005, 11:31 AM
  2. 9pin mini din connector
    By corsab in forum LCD/Display
    Last Post: 11-21-2004, 08:39 PM
  3. Replies: 10
    Last Post: 08-12-2004, 05:45 PM
  4. Hard wire the Lilliput DIN connector
    By Bobby Digital in forum LCD/Display
    Last Post: 06-18-2004, 04:00 PM
  5. 13 Pin DIN Connector
    By UncoCow in forum General Hardware Discussion
    Last Post: 11-21-2002, 06:46 PM
