Page 1 of 11 12345678910 ... LastLast
Results 1 to 10 of 110
Thread: LiquidVideo LVM701 DIN Connector?
    Maximum Bitrate Sidewalksalvage's Avatar
    Mar 2006
    NJ/RI
    Question LiquidVideo LVM701 DIN Connector?
    Hey I have just bought an LCD off ebay and it is missing one connector. It is the A/V input. I was wondering if I could get a pin-out or some information on where to buy it. It is a 8 pin connector in a circle the size of a PS/2 connector. I have attached a picture (it has 2 inputs).
    Brown 2010
    Mar 2006
    NJ/RI
    No one responded to this post.....so the may be a useless post....
    But I discovered the composite video pinout for the LiquidVideo LVM701
    Brown 2010
    Newbie BIGVANGUY's Avatar
    Apr 2006
    Ontario, Canada
    pinout
    Hope this helps. I have a thread on this obviosly in the wrong section.
    I'm looking for a manual.
    Mar 2006
    NJ/RI
    Wow thanks that helps a lot!
    Brown 2010
    May 2006
    Muncie, Home of the 4 Speed
    Same situation
    Hey, I have the same video screen, is there a way I can create a DIN cord then, or what do I need to do to power this thing up? Please HELP ME!!!
    Mar 2006
    NJ/RI
    You can power the unit throught the din if you need to, but there is also a spot where you can solder 2 wires for direct power input. if you can take some pictures of the board, i may be able to point them out.
    If you want to make the din, if you can get a A/V connection for a laptop (it looks like an s-video with extra pins) you can then clip the end, and solder your own connections to it
    When i get home tonight ill try and see if i can get some pictures of my unit. so i can illustrate better
    Brown 2010
    May 2006
    Awesome
    YEs, if you can show me pics of how you did it, that would be much appreciated...since i have no clue as to what I am doing...lol.
    Thanks again!
    Mar 2006
    NJ/RI
    Lol...
    I have to re fabricate my case anyway....its sort of medical taped together, i havent had time to create a metal one yet....
    Im happy to take some pics and see if i can help.
    I have an old conenector that i found, that may be the same pin number...if i can hack it to work with the liquidvideo, im happy to sell it to you....
    Brown 2010
    May 2006
    totally
    Yea dude, totally...I need something to work...can you take some pics of how you got yours to work, or can you give me a detailed description on how to solder wires in or something...thanks
    Apr 2006
    Ontario, Canada
    Making a DIN cord
    Actaully I have made a couple since I posted the pinout. And I have done some experimenting, with much success. I have figured out that the orignal power wiring harness has a large choke (or maybe a volt regulator) on it, and the unit should only be powered with that power harness. The 12 volt in the din connector I think is a 12 volt out and was put there to power an input device of a low amperage. What I did with it was I used it to power my second in-dash pyle 7" which I had bought second hand and I had to make a wiring harness for also. You can splice the cut din cable to a cut rca cable making sure you have some tin foil to wrap around the entire spliced area making sure it has contact with the original ground shield on all wires, then wrap the whole mess in tape. The din cord I used was an old mac extension cable I picked up at a surplus store.
  1. Replacing connector in Lilliput
    By Chairboy in forum LCD/Display
    Last Post: 05-04-2005, 11:31 AM
  2. 9pin mini din connector
    By corsab in forum LCD/Display
    Last Post: 11-21-2004, 08:39 PM
  3. Replies: 10
    Last Post: 08-12-2004, 05:45 PM
  4. Hard wire the Lilliput DIN connector
    By Bobby Digital in forum LCD/Display
    Last Post: 06-18-2004, 04:00 PM
  5. 13 Pin DIN Connector
    By UncoCow in forum General Hardware Discussion
    Last Post: 11-21-2002, 06:46 PM
