Results 1 to 6 of 6
Thread: Got partial shipment from DennisK (Screen and Touch coming...)
    FLAC LESLIEx317537's Avatar
    Jan 2002
    Long Island, NY
    Arrow Got partial shipment from DennisK (Screen and Touch coming...)
    I got my DigitalView controller card and inverter and hirose cables today from Dennis K.
    Anyone else who has this can you help me on the inverter? It has 4 pins in and the controller has a 4 pin out called CNA1. Is that for the inverter? I'm assuming once I hook up the OSD controller and hit the OSD brightness keys it will vary the voltage to CNA1 therefore adjusting the backlite? Anyone???
    I need my screen......I want to play. And touch.
    SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
    GPSing - Digital Speedo
    Relocating headunit and extending faceplate
    Button app to Alt-Tab between two programs
    Jan 2002
    Long Island, NY
    I htink it's CNB1 now. I looked at some PDF.
    I don't wanna fry this thing so I'm gonna make sure everythings 100% before I press the red button.
    FLAC mp3z24's Avatar
    Apr 2001
    Chicago Suburbs
    heheh. i got half of my package on friday... screen and touch controller.
    im waiting on the stuff that you have. they should be at my house this afternoon.
    cant wait... i still have to figure out the power to the touch cable.
    ~mike
    Single Member of the "1000 Post and No MP3 Car" Club
    PROJECT ON INDEFINATE HOLD... BOUGHT A HOUSE
    2000 Cavalier Z24 [###-------] Only 30% Done ... Still
    Jan 2002
    Long Island, NY
    Cool, then we can work on this together. Nice. Keep in touch.
    You got my AIM SN?
    The power to the touch is easy. What do you want to power it with? You can run power from serial end or if your touch board is by another power source you can use that.
    Feb 2001
    Somerville, MA
    Which way does the cable from the touchscreen to the controller go? It seems like it fits both ways...
    Did you just go to RadioShack and pick up a connector for powering the thing via the cable?
    Twostep
    Apr 2001
    Chicago Suburbs
    i havent done anything to power it yet. i will probably go to the Rat Shack and pick up a cheap mini-power plug that will fit the serial cable. and i will probably wire it off the sproggy 5V rail. (thats the correct volatage....right?)
    as for the cable from the touch screen to the controller. i believe that if you have the controller sitting in front of you with the pins pointing away from you, the wires should go to the left. i havent had the chance to try it yet, but i might test the pins with a voltmeter to see which ones are putting out a signal. obviously, some of them are going to be dead (no connections).
    LESLIEx317537 :
    i dont have your aim name, but i think i can get it from the profiles area. if not i will send you a message. we can discuss how to put all this crap together as soon as it gets in.
    ~mike
