Results 1 to 4 of 4
Thread: Molex powering LCD using cigarette lighter cabling?
    Constant Bitrate ironic's Avatar
    Aug 2005
    Gibraltar(UK)
    Question Molex powering LCD using cigarette lighter cabling?
    Hey guys.
    Im gonna power my lcd (LinITX 7" touchscreen from my psu.
    Ive read i can use a molex adn so it shall be.however im concerned about the thickness of the wire inside the cigarette lighter that i have to use to connect to the molex wires.
    as you can see below, or mite not, sorry bout low quality, the molex cables are a lot more thick than the wires inside the cigarette lighter.
    Is this safe?Should i use those cables and connect them to the thicker molex wires?
    btw i checked the cables from the the ac converter taht came with the lcd and they are a lot thicker too.am i better off using these instead of the cigarette lighter??
    thanks guys
    MSI KM4M-V Mobo -- AMD Athlon XP-M 1900+ -- 512MB DDR RAM -- LinITX 7" Touchscreen -- Seagate 8.4GB HDD -- LG DVDRW -- Onboard Graphics Card -- Onboard 5.1 surround sound -- Bluetooth Dongle -- RoyalTek Saphire GPS -- M2-ATX psu
    Feb 2006
    I think the wire size it came with (stock) is sufficient. I don't like them just because they are fragile and it is hard to get a good connection between large wires and small wires. That is why I soldered those two together.
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    It's fine. The LCD only take an amp or 2.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Sep 2005
    Yeah, the 7" Lilliput only pulls .75 amp (9w/12v), so I can't imagine the LinITX screen draws much more. That wire should be fine. How far are you going with it? Much more than 6 feet and you might want to consider making it a larger gauge.
  1. install an inverter without running to cigarette lighter
    By FodderCom in forum Power Supplies
    Last Post: 10-06-2005, 01:20 PM
  2. Looking for a cigarette lighter socket for Lilliput
    By Proplus in forum LCD/Display
    Last Post: 10-24-2004, 07:27 PM
  3. Cigarette Lighter dead
    By c4shm0ney in forum Power Supplies
    Last Post: 07-27-2004, 02:56 PM
  4. lilliput Cigarette lighter fried.
    By lbk in forum LCD/Display
    Last Post: 06-21-2004, 04:56 PM
  5. Powering LCD from car?
    By King_Xerxes in forum LCD/Display
    Last Post: 04-04-2002, 04:48 AM
