Results 1 to 7 of 7
Thread: Can I extend this plug?
    Low Bitrate NoTicketsPlease's Avatar
    Jan 2006
    San Diego, CA
    I dont want to screw up anything so im asking. Have searched.
    Can I extend the white and red wires in the picture? I need about 3 to 4 extra inches. This is a lilliput 8" Model #: 809GL-80NP/C/T
    Is this a special kind of wire or anything else I need to know?
    Could I use crimps or do I have to solder?
    Thanks!
    Windows XP is ****!!!
    AMD Sempron 3000+, ASRockVM800, 256MB, 250GB 3.5", DVDRW+, WIFIg, m2-atx, Lilliput 8", RR, GoogleEarth
    Need: daylight viewable screen!
    Banned Motorcity's Avatar
    Apr 2003
    Detroit, MI
    yes, you can extend those wires. However, you do need to use the correct wire type. Those are high voltage, AC wire, and require specific properties that standard wire do not offer. Others here will tell you they have done it using regular wire, speaker wire, etc. But, do you want to play with 1000 volts AC?
    buy the right wire, solder, not tape, then cover all connections with heatshrink tube.
    http://www.mouser.com/index.cfm?hand..._pcodeid=56005
    If you don't want to deal with it, let me know.
    Jan 2006
    San Diego, CA
    Quote Originally Posted by Motorcity
    Thanks for the quick reply. Of course I dont want to deal with it but what could you do? Is there an extension cable or something?
    Apr 2003
    Detroit, MI
    Quote Originally Posted by NoTicketsPlease
    I can extend the wires for you in my shop, if you wanted, or I can make an extension cable.
    I would need to see better pics of the connector to make sure I have the right parts to make it. Otherwise, I would just remove the existing wires and solder in new, longer lengths.
    Jan 2006
    San Diego, CA
    An extension cable would be very nice. Here are the plugs. This is the newer lilli.
    Apr 2003
    Detroit, MI
    ok, I have those connectors here.
    I will make an extension cable for 7.95 shipped.
    please make sure 4" is enough
    pm your email, I will send a paypal invoice.
    Jan 2006
    San Diego, CA
    4" is perfect. PM sent.
  1. Antenna plug to 3.5mm
    By CaPiTaN in forum Car Audio
    Last Post: 08-13-2006, 03:15 PM
  2. Gathering Ideas . . . Disconnect plug for Opus power
    By J187 in forum General Hardware Discussion
    Last Post: 06-01-2005, 12:29 PM
  3. Extending Din plug on Headunit?
    By NiN^_^NiN in forum Car Audio
    Last Post: 03-01-2005, 01:37 PM
  4. converting my radio plug
    By nappyjim in forum General Hardware Discussion
    Last Post: 02-14-2005, 01:47 PM
  5. Replies: 5
    Last Post: 07-12-2003, 02:43 AM
