Results 1 to 4 of 4
Thread: replacement digitalww touchpanel not as sensitive
    Variable Bitrate numbers's Avatar
    May 2005
    Has anyone else replaced their 7" lilliput touchpanel with the unit from digitalww? I just did and the new one is much less sensitive to touch. The old one would respond at the slightest touch, and the new one needs more of a push to respond. It's annoying. It makes dragging windows and scrollbars more intermittent and more likely to scratch. Normal?
    bai
    bai is offline
    Apr 2006
    I just replaced mine myself a couple days ago and noticed the same thing. I also noticed it's significantly more...."rainbowy" than my old one was. Seems it diffracts the light more than the original one does or something like that. Anyone know of a solution to either of these two problems? I would assume if there were some way to "bond" the touchpad to the lcd to fill in the gap between them (vaguely like heatsink paste on CPUs, only more see-through) it would help. Anyone played around with this problem before?
    Low Bitrate DaKyy's Avatar
    Apr 2005
    Finland
    What if you have installed it wrong way around?
    May 2005
    Quote Originally Posted by DaKyy
    Then it would have been impossible to connect it to the controller.
  1. Someone ordering at digitalww?
    By DJSmiley in forum Classified Archive
    Last Post: 04-30-2005, 04:49 PM
  2. Digitalww - replacement TS
    By Paul_ in forum LCD/Display
    Last Post: 01-03-2005, 11:55 AM
  3. DigitalWW Lilliput Touchscreen Replacement
    By archimense in forum LCD/Display
    Last Post: 12-15-2004, 03:17 PM
  4. Props to Armen at DigitalWW
    By archimense in forum General MP3Car Discussion
    Last Post: 11-16-2004, 03:24 PM
  5. DigitalWW LCD Screens
    By edmcgee in forum LCD/Display
    Last Post: 09-26-2003, 12:18 AM
