Results 1 to 10 of 10
Thread: Saturn Vue Din Size
    Apr 2006
    orange county ca
    Saturn Vue Din Size
    I am a newcomer to these forums and did some pretty deep searches for some info but couldn't find what I needed.
    Has anyone installed a screen into a saturn vue?
    I am picking one up next week and want to find out how an in dash 7" would fit in the din. How much modification it would need. I am thinking about a mtorized if the din is not big enough. any info you guys could share will be helpful.
    Mar 2006
    Colorado, but Canadian!
    A double din hole is just about perfect for a 7", so if the Vue has a double din, then a 7" will fit well.
    Newbie Black_Sheep's Avatar
    Feb 2006
    Coxsackie, NY
    Most GM vehicles use a custom size commonly refered to 1.5 DIN. If you search on www.crutchfield.com you won't find any 2 DIN or Double DIN radios that fit your car.
    If you make something Idiot proof....
    The world will make a better Idiot.
    CarPC Progresss: Planning [x-------------------]
    Mar 2006
    Well there you go, If you have a GM, your screwed...
    Maybe a smaller screen? Or a hell of a lot of chopping up your dash I guess.
    Apr 2006
    orange county ca
    So saturn is considered GM? didn't know that.
    I may go witht the motorized in dash unit then. anyone have any saturn Vue specific info that they think may help me?
    Thanks. I am really excited to get this all together and installed.
    Apr 2006
    Saturn is a wholely owned subsidiary of GM. I have an L-series and it's much the same. You can get a single DIN adapter and install a Xenarc 700IDT or custom fit a monitor in there. I'm going the custom route right now.
    Variable Bitrate JasonMK's Avatar
    Jun 2007
    Annapolis, MD
    Does this mean a Double-Din unit like the Infill G4 won't fit?
    Elsewhere
    Quote Originally Posted by JasonMK View Post
    Correct.
    How about the Wiki?
    Jun 2007
    Annapolis, MD
    Which demension (width, height, depth) makes the GM stereo not double-din compliant? The demensions I have for the G4 is w=6.93" h=3.94" d=7.5. I pulled out my factor head unit and measured an 8' (wide) opening
    and the current stereo is 4.5" (height).
    My only question has been depth, but depending on how it sits and how I mount it I should have some play there.
    Jun 2007
    Annapolis, MD
    Quote Originally Posted by DarquePervert View Post
    Correct.
    My G4 arrived yesterday, had it installed smoothly before dinner. Looks like this GM (Saturn VUE) is double-din. The only glitch was the Metra kit needed to be trimmed, a few times. Luckily I had some good advice on how to handle that.
    You can also use a razor knife if you heat it up with a torch or a lighter.
    VOILA!
    A hot-knife.
    Worked like a charm (no lighter, used a candle, added a nice scent too!)
  1. Saturn Vue PC
    By Jmiller808 in forum Newbie
    Last Post: 08-31-2006, 09:49 PM
  2. Saturn Vue install coming!!
    By bennyek in forum MacCar
    Last Post: 04-21-2006, 12:17 AM
  3. DIN Size Question and other stuff, help me out.
    By airmcnair06 in forum Newbie
    Last Post: 03-30-2006, 07:00 PM
  4. LCD screen size for double din opening...???
    By EclipseGSturbo in forum Newbie
    Last Post: 01-30-2006, 01:24 PM
  5. DIN size
    By bombboyer in forum General Hardware Discussion
    Last Post: 10-31-2002, 07:53 PM
