I have not had that kind of behavior, nor do I own this screen, but is it supposed to fully close when you push close and it's up? In the video, it stops, flashes and then you push again and it goes in. Did it do that before? If it were just the screen going crazy, I would check the ribbon calbles going to the screen including the power to see if it is loose. But if the motor function is not working either, then I would think total system failure. Get an RMA if that's the case.
LinkBack URL
About LinkBacks
