Results 11 to 20 of 23
Thread: PIC Backup Camera Source Switcher for Lilliput
  1. #11
    Raw Wave shotgunefx's Avatar
    Apr 2005
    Boston, MA
    Cool.
    I'll have to look into this a bit more when I have time. It's been on my to-do list.
    Off the top of my head, I don't see why you couldn't use an optoisolator + resistor for both K1 and K2.
    I don't think floating pins can damage a PIC, though their values are subject to, um float between 0 and 1.
    If you want to pullup/down a lot of pins, you could just use a SIP resistor array, would take less space, lot less joints to solder too.
  2. #12
    Apr 2005
    Boston, MA
    One more thing, connecting CLKIN direct to ground should give you a 10MHz oscillator - no components needed.
    I'm pretty sure this works on the PIC16F84A, it works on the 16F627A which is pin compatible replacement for the 16F84A.
  3. #13
    Feb 2006
    Quote Originally Posted by shotgunefx
    I think you are incorrect. The 84A has no internal oscilator. It is speced to 10MHz only if you use an extrernal oscilator (not RC curcuit). The max you can get out of an RC curcuit is 4MHz.
  4. #14
    Apr 2005
    Boston, MA
    Quote Originally Posted by EricE
    I think you might be right on the external oscillator, I usually use the 16f627 or 16f628 for no particular reason other than the first books i had used them, though you could sub one of those to cut down on component count (or rather, other people building the circuit).
    I believe there are two different versions of the 16f84a, a 4mhz and 20mhz.
    Here's a 20 mhz one.
  5. #15
    Dec 2004
    What camera did you use?
    06' BMW 330i
    SG|Beige Dakota|Poplar|iDrive w/MP3|PP|SP|CWP|PDC|Comfort|Shades|40% Tint
  6. #16
    Feb 2006
    The one sold in the store.
    http://www.mp3car.com/store/product_...roducts_id=166
    I have no complaints.
  7. #17
    Apr 2006
    Sydney, Australia
    Great work there mate!
    Would this be hard to use a 509A pic? instead of the 16F just to reduce size? Or is the code to big to fit?
    New Car PC Build list in progress
  8. #18
    Apr 2005
    Boston, MA
    I was thinking of trying something along these lines this weekend for my 8" lilli.
    But then I had another thought. Can the monitor's status (on/off) be determined by DDC? I'm wondering, if it's possible, maybe I'll just use a PIC to operate the monitor by IR remote.
  9. #19
    Feb 2006
    Quote Originally Posted by Kosti View Post
    If I read it right that PIC has 1K. 1K is plenty of code space.
  10. #20
    Feb 2006
    Quote Originally Posted by shotgunefx View Post
    Having the PIC determine if the LCD is on or off is a good idea. As it is, I have the PIC code go into a waiting loop for 5-7 seconds while it waits for the LCD to turn on. That is because I have the PIC powered off the car-on but the monitor comes on when the computer powers up. Any signals sent to the LCD before it is on is obvioulsy not going to cause anything to happen. Of course, that could probably be removed now that the PIC can detect what state (VGA v.s. non VGA) the LCD is in. When it couldn't detect state that was much more important because any signal it sent to the LCD was assumed to change the LCDs state. I guess the next time I have the LCD out I'll change that bit of code in the PIC. But I haven't had to touch my setup for many months. It works perfectly except that (because of the delay loop) it won't switch to backup camera the moment the monitor turns on if I am already in reverse [which is usally the case when I am backing out of a parking spot.]. Its a small thing though.
  1. why is my backup camera not working with my capture card?
    By nappyjim in forum General Hardware Discussion
    Last Post: 02-17-2005, 02:52 PM
  2. master volume doesnīt work
    By free2world8000 in forum RR Bug Tracker
    Last Post: 02-17-2005, 12:08 PM
  3. Update: 2-12-05.. Flash Support!...
    By guino in forum Road Runner
    Last Post: 02-13-2005, 12:21 PM
  4. Rear camera view switcher (automatic)
    By M^ck^y in forum General Hardware Discussion
    Last Post: 09-07-2004, 05:40 AM
  5. Questions for developers
    By SuperG35 in forum ME Archive
    Last Post: 08-26-2003, 10:12 AM
