I have a few questions...
Which way did you connect the touchscreen->controller cable? It seems to fit either way.
Did you end up powering the touchscreen controller from the LCD controller as you had planned to do?
You mentioned before that you were having color troubles, what did you have to do to fix that?
Twostep
The touch cable from the overlay goes on so that the wire heads towards the other connector. Like here:
I haven't powered it from the tft controller yet, but is very easy.
The color troubles I was having was the 12 bit colors. I went into PowerDVD's video settings and turned the contrast ans saturation all the way downa nd it helped get rid of the rainbowy effect a little.
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
