Results 1 to 5 of 5
Thread: how I can take out this screw ?
    Mar 2006
    hi guys, I have a lilliput 7'' TS. and I try to install it to the dash, so I took everything apart, but unfortunately I mess up ribbon cable, so I ordered 1 from mp3.com/store and I tried to replace it. at the time I took out the screw inside the screen and the screw is too small for the screw driver, so now I messed up with the screw and today I went to the ACE hardware store, and bought a mini screw driver, but there is no way to take that small screw in the screen. Any idea how I can take out that screw ? thank you very much ?
    ribbon cable
    FLA gospeed.racer's Avatar
    Dec 2003
    Portland, OR
    Usually once the head is destroyed you are best off drilling it out with a small bit. Find a drill bit that is about the same diameter as the threads. Drill down until it just sprins the head off the screw, and STOP. Once apart, you should hopefully have enough nub left to remove it with a small set of pliers (I prefer diagnonal cutters, they grip well)
    2005 Ford Focus ST
    Mar 2006
    I am scare to mess it up again, I am about going to the electronic's store. such as computer place and ask them to remove it for me, thanks for help.
    Maximum Bitrate psyrex's Avatar
    Jun 2005
    Oakland, CA
    Once a screw is stripped, you either destroy the screw by drilling it like gospeed.racer said or you destroy the plastic that it's screwed into. If you're lucky (very VERY lucky), you can still remove the screw by just using a pair of pliers (the bent nose kind, perhaps) and turning it. Likely you gotta break something.
    FYI, if you are going to drill out the screw, please please protect the rest of the board from metal shavings shorting out stuff... the kind of mistake you only make once in a lifetime. *sigh*
    -psyrex
    Gen 1: Pentium 3 1GHz - ATX - 2005
    Gen 2: Pentium M 1.6GHz - ITX - 2006
    Gen 3: Pentium M 2.0GHz - 5.25" SBC - 2007
    Gen 4: (coming soon: Core2 Duo - 3.5" SBC - 2009)
    ...it never ends
    Mar 2006
    Portsmouth, UK
    I'm not sure just how small this screw is, but i normally have a very small cutting disc on a dremel that allows me to cut a new slot into a bust screw which is just enough to let a flat head screwdriver catch on it.
    Wolfsbane2k
    Fitting out a Skoda Octavia GLX.
    Progress [__________] (ie nothing yet!)
  1. I Have Metal Sheets - How do I Add Screw Holes
    By ccsnet in forum Fabrication
    Last Post: 04-30-2006, 06:40 PM
  2. Recommend using Set Screw Power Rings?
    By matt11601 in forum General Hardware Discussion
    Last Post: 03-13-2006, 11:36 PM
  3. DSATX - Did I screw something up?
    By randomjohn in forum Power Supplies
    Last Post: 01-13-2006, 03:16 PM
  4. Screw the Screw the old 'so cal meet' Thread!! Date Set 7/16/05
    By 12Vsystems in forum MP3Car Gatherings
    Last Post: 07-25-2005, 12:35 PM
  5. Looking for really compact/delicate cordless screw driver
    By kingtut in forum General Hardware Discussion
    Last Post: 11-27-2004, 01:55 AM
