Ummm, maybe right here?
Hi all, I have a 2001 Honda Civic, and it has a 7.5" x 4.5" space where my stock stereo used to be. I'd like to put a touchscreen in there, and I'd like to maximize the use of that space. All the touchscreens I see on mp3Car.com have huge frames/bezels with buttons and stuff that I just don't need. Based on my calculations, I should be able to easily fit an 8" 16:9 screen in there (maybe even an 8.5"). Anyways, Where can I find one of these? Could I just buy one of these and just take the screen out of the frame/bezel?
For Sale: Carputer (CarPC) & RCA Y-Adapter
Newsflash: Take a look at my unsold stuff above, thanks!
Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
Check out this 2001 civic install with a 7 inch touchscreen
2001 Honda Civic Aopen Pandora MiniPC
Civiputer: Dont have one anymore, but here is what is used to be!
That's awesome. It's nice to see that it can at least be done. However, that guy used the whole screen, bezel and all. I was hoping I'd be able to use the touchscreen without the space-wasting plastic bezel. Has anyone tried that?
Well, if you take a look at my 2003 civic install, you will see that you atleast have to use some of the bezel. I had to cut my bezel down a lot, and then used a plastic trim piece for the surround. The only part of the bezel that I used was the front part, heavily cut and the back part of the case is completely removed. Check it out here
2003 Honda Civic.
