Hey guys,
I am a noob but this is beyond a noob question...
I have the 10.4 xenarc touch screen connected to the carputer i just built.
I booted up for the first time and everything went ok, except my slot load wouldnt load CDs.
I opend up the cast and fiddled around, closed her up, but when i turn it on now, the MONITOR WONT read an input signal. It says no signal input, with no other messages...
It flashes no input for a few secs and then goes into standby. To test, i put my desktops monitor on the carputer, and still no signal.
Without a monitor i cant go into the bios or anything...
PLEASE HELP!!
-keith
For Sale: Carputer (CarPC) & RCA Y-Adapter
Newsflash: Take a look at my unsold stuff above, thanks!
Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
I am using the MII12000 on-baord bios...How do i do a bios reset? Id assume that is Indeed what i need to do, but i cant see anything to access the bios...Originally Posted by DJiK
Is there a way to do a hard rest on the board manually?
-Keith
Please share how you solved it so that the next newbie who's got the same problem knows how to deal with it.
Well it was a foolish mistake in itself...
When i messed around with the CD drive (which i still havent gotten to work), i had the IDE ribbon going to my hard drive on with the split power at pin 1 instead of the ribbon power...
I corrected the IDE setting and now everything is dandy except that the slot load drive wont take cds!
-Keith
