Results 1 to 7 of 7
Thread: Newb Q: Screens & Square VESA 75/100?
    Low Bitrate double-0-newb's Avatar
    Jul 2005
    Montreal
    Thumbs up Answered: Screens & Square VESA 75/100?
    Hello,
    I am about to order a 4.75'' Square VESA 75/100 Compatible Plate from
    http://www.gpscity.ca/item-ram-mount-vesa-75-100-compatible-monitor-plate-with-1.5''-ball/ram246.htm
    and I would like to know if the Xenarcs, Lilliputs and others have this same mounting pattern?
    Searching and looking at pictures (like this one http://www.digitalww.com/VGA_TM_710VG.htm)
    either confused or did not answer that particular question.
    Anyone? Thanks in advance.
    1998 Volvo V70 "Volputer"
    Worklog: planning and procurement.
    http://www.mp3car.com/vbulletin/worklogs/75505-1998-volvo-v70-for-now-libretto-100ct.html
    Banned Motorcity's Avatar
    Apr 2003
    Detroit, MI
    A VESA mount is a standard size, but usually only found on 12.1" and larger lcd monitors. I highly doubt the smaller 7-8" units out there will accept a VESA mount.
    Jul 2005
    Montreal
    Thanks Motorcity.
    So if I did want to use one of those mounts to hold one of those monitors, it should not be too big a deal for me to simply remove the back panel, line-up the and mark the holes placement and drill and mount? Think there would be enough clearance between the plastic back and the guts for some nuts/bolts?
    http://www.mp3car.com/vbulletin/showthread.php?t=75505
    Variable Bitrate nameeri's Avatar
    Mar 2006
    SoCal
    NO!! There is no spare room for mounting brackets or hardware on the back of these small screens. the LCD controller board rests against the back of the plastic case. Do not use a VESA mount on small monitors.
    Civiputer: Dont have one anymore, but here is what is used to be!
    Jul 2005
    Montreal
    Mimicking my 2 yr old "But, I wanna!"
    Ok, thanks for that info nameeri.
    Any suggestions then? I was planning on mounting my "unit" (still in development phase; either Libretto100CT or iPAQ or small laptop monitor) just in front of my vents in my Volvo V70, and I would like it to be adjustable and pivot to face the passenger. I am going to swap-in a single DIN HU and use the open space to fashion a plate onto which can mount a bracket, 9-inch arm, then the pivot VESA head. The VESA head I thought would be ideal for either the Libretto or laptop screen (with mods), and wanted to know about the future-upgradability to a Lilli or Xenar (or other) keeping that same mount.
    Pic of my planned install
    Pic of parts to be ordered (note how some are were just carted out of interest)
    Mar 2006
    SoCal
    Whatever monitor you purchase will come with a mount, a small one anyways for it to rest on a table. usually, these mounts come in two or 3 pieces. The first piece fits onto the back of the display. The second piece (or 2 pieces) make up the arm which attach to the 1st piece. If you fabricate some sort of arm, you should be able to use the mount pieces that you get.
    Jul 2005
    Montreal
    Great. Done. Locked (if I can find that button...)
  1. FAQ: VGA vs. Composite (Video) Screens
    By cproaudio in forum The FAQ Emporium
    Last Post: 12-28-2007, 12:45 PM
