Results 21 to 30 of 39
Thread: Is the sunlight problem really _that_ bad??
  1. #21
    Variable Bitrate nameeri's Avatar
    Mar 2006
    SoCal
    Look at the tranflective review I did. there is a pic of a laptop that has just the 3M anti glare treatment and see for yourself. It wont help for Xenarcs or Liliputs with a touchscreen.
    Civiputer: Dont have one anymore, but here is what is used to be!
  2. #22
    Apr 2006
    Utah
    Is seems to me that a lot of the complaints come from convertable owners. Does having a non-convertable help with the viewability? I'm also in kind of a holding pattern on a screen. I have just about everything else ready, I just don't want to waste my money on a screen that I will be disappointed with. I also have a limited budget and can't see a sunlight viewable getting into the $250 dollar range anyway.
  3. #23
    FLAC alti's Avatar
    NY
    There are daylight viewable solutions out there, just not a single one that is easily or cheaply availible. I have a 2000 nit screen in my dash that I run at 1000 (half of the are backlights on) because i do not have a convertible / moonroof and it is blinding at night. But i have no problem reading it during the day. In the end it only cost me around 450-500 for the screen, (controller, screen, inverter, ect) what it did cost me though is months of research, and effort.
    Where there is a will, there is a way. If you are willing to invest the time, you will find what you are looking for
    My Install
    Software:
    CFiG v1
    iGuidance Plugin for CF
    CarShell
    Working shell for a CarPC
    StopWatch
    StopWatch plugin remade for centrafuse RC1
  4. #24
    Newbie monkeyBox's Avatar
    Apr 2006
    Quote Originally Posted by alti
    Care to share your secrets of success? If I found even a 1000-nit screen, I think I'd be happy. I've found some sites with 1000-nit screens, but not in the size I'm wanting (7-inch 16:9).
  5. #25
    FLAC alti's Avatar
    NY
    I did above, you get out what you put in.
    From start to finish it took at least 5 months from first planning to actually having the screen in the car.
    If there was a link that would solve the delema, I would post it, beleive me. I am not tring to preach from a soapbox here, if i knew what i was getting myself into when i started the process I probibly would have choosen a xenarc and called it a day, all I am tring to say is that it can be done (its wether the total cost monitary and non is worth it).
    Good luck with your project.
    My Install
    Software:
    CFiG v1
    CarShell
    StopWatch
  6. #26
    Feb 2006
    If you are contemplating an install and holding off because you are afraid the screen will be unusable then relax. Yes, it’s a pain but it doesn’t ruin the install. The value is there even if you have a regular lilliput. I myself am going to take the plunge….order a new screen (a Xenarc this time for the better controller, send it off to get a TS and Trans mod…then mod my bezel to make it fit) The only reason I can afford to do this though is that I am spending poker winnings, not real money. hehe
  7. #27
    Aug 2004
    I say its worth it still, but only if you have a secondary control method.
    The best is steering wheel buttons. The next best would be some kind of controller, at the very least, a volume knob. The griffin powermate works well. There's all kinds of good projects and suggestions in the input devices section, so I wouldnt worry about it.
  8. #28
    May 2005
    I am finding that the Xenarc touch screen almost turns into a mirror when the sun hits it through the sunroof... I have to squint quite a bit to avoid being blinded.
  9. #29
    Apr 2006
    Quote Originally Posted by sebberry
    Wow, good thing I don't have a sunroof
  10. #30
    Apr 2006
    I'm curious, what are the brightness ratings (nits) on the Lilli and Xenarc?
  1. Audio muted problem
    By Tsleon in forum RR Bug Tracker
    Last Post: 10-20-2006, 06:09 PM
  2. Computer Building Problem
    By 0l33l in forum General Hardware Discussion
    Last Post: 05-09-2005, 02:52 AM
  3. BU-303 problem (software related)
    By blazinlow in forum GPS
    Last Post: 02-14-2005, 08:59 AM
  4. Auto power off
    By accord in forum General Hardware Discussion
    Last Post: 08-15-2004, 08:08 AM
  5. 7" REDANT SCREENS (bad pixel) CHEAP
    By dscustoms in forum Classified Archive
    Last Post: 06-26-2002, 11:04 AM
