how can you prevent overheating if there are no vent holes in the case?
i doubt you can "perfectly" seal the case, how will any condensation/moisture get out?
what if the passenger puts the visor up and a rock hits the screen, or worse yet, what if the thing gets ripped off the visor when you are doing highway speeds with the top down?
i see too many possibilities for a lot of damage to a lot of your components. sorry to say, but i think this setup has a lot more thought needed.
~mike
edit....
"Jeeps have a lot more headroom than most passenger cars"
--- yes, but if you have a visor with a 15 inch screen hanging off it, there is going to be very little room to see out the windshield. i assume this is a wrangler, and when i was in my buddies at school, the windshield was only about 15 inches tall. that would probably leave about 1-3 inches at the bottom, right above the dash. think about it!!
LinkBack URL
About LinkBacks
so you should be OK on the water proof front as it'll only be exposed to a bit of moisture.
