Page 5 of 5 FirstFirst 12345
Results 41 to 47 of 47
Thread: New Lilliput 8" 889GL-80NP 16:9 (Pics included)
  1. #41
    Feb 2006
    it seems that eby701 has no pb displaying 800x480
  2. #42
    _Dejan_'s Avatar
    Jul 2007
    Slovenia
    I have onle little problem, when Im open my screen(Lilliput 889GL-80NP) and remove connector for buttons&IR Im broke it in one side and cables has fall out from connector :S Can someone tell me which PIN is connected where? Is 1to1 connection or are cables mixed between? Can comeone have this cable for sale?
    Thanks for any help.
    Regards, _Dejan_
  3. #43
    Feb 2006
    cable
    hy dejan, it' straight forward
  4. #44
    _Dejan_'s Avatar
    Jul 2007
    Slovenia
    Quote Originally Posted by dydycom View Post
    Hi,
    Im find solution Im mesaure where is ground on good connector then Im mecaure where is ground on PCB and then Im try connect 1.pin on cable to 1.pin on pcb and work ok. I will use half connector to make pins isolated and "glue" it with hot glue
  5. #45
    Jul 2005
    G'day all,
    Has anybody got the actual dimensions of the 889 panel without the casing, I need to fit the panel into a hole which is 176 x 105 mm. I have seen post # 7, but I think he has taken the measurment while the case is still on. Thanks in advance...
  6. #46
    Feb 2006
    post 20
    did you read through all 3 pages?
    post 20 might enlight you
  7. #47
    Jul 2005
    Thanks dydycom I did read through, I missed that one though. Its quite a bit bigger than the measurements mentioned in post 7, and it doesnt specifically say the measurement is with no case.
    Appreciate your measurements, thanks for helping.
  1. 8" Lilliput question, extracting sound and screen rolls
    By clean customs in forum LCD/Display
    Last Post: 06-30-2005, 11:10 PM
  2. Replies: 1
    Last Post: 01-31-2005, 12:35 PM
  3. 8" Lilliput Touchscreen Info
    By Mrbmw99 in forum LCD/Display
    Last Post: 12-13-2004, 02:31 PM
  4. 8" Lilliput adds noise to my stereo
    By MSUC5Vette in forum LCD/Display
    Last Post: 10-11-2004, 04:33 AM
  5. Pinouts/connections technical stuff on 8" lilliput.
    By chargin in forum LCD/Display
    Last Post: 07-21-2004, 09:55 PM
