It's two months later and I'm still happy with this mount except for one small thing-- the two screws holding the neck to the mounting bracket (the bottom bracket which is held to the ground by the seat's bolt) have come loose and the mount is swaying back and forth whenever the car turns. It shouldn't be hard to fix this, as the screws can be tightened, but I have to find a torx bit small enough to fit the small screws! Other than that, it's a great mounting solution that was easy to install.
LinkBack URL
About LinkBacks
