WTF it's obvious...there is a DFP connector on the back of the screen pointing sideways (the cable does not prootrude past the side of the screen). This cable is about 1.8m long and has a vga, 3 RCA and usb connectors at the end.
Could somebody tell me where the VGA connector is on the Xenarc 700TSV. Looking at the pictures on the website, its looks like its on the side... Mine is not going to be mounted in the dash and I want to make sure it won't look crappy with a vga cord sticking right out of the side of it. Pictures would be excellent if you have them.
Just measuring twice before I cut.... Thanks
you dont need to run a vga cable all the way up front. if you do you will have loads of cable in the dash. normally you can get away with the 3m not the 5m cables. no point in having extra.
good luck.
