I've got no answer!
in other words, use the connection from your computer (the picture I posted...the connector is called a "molex connector"..) and yes, it should be ok to make a long wire from your power supply to the lcd.
do not do what this guy is saying please.... just run like 22 guage wire up to the front of the car and your fine....
Originally posted by kipou
yeah, the pic that fcc had is what the connector looks like, can i just make a longer versin of that wire myself
YES
I think that answers the question
And you say people actually pay money for M$ Windows?
www.mp3mini.co.uk (Does what it says on the URL) www.openclassic.co.uk (The new car, with zero rust!) www.rob-web.co.uk (My other site)
Total re-design underway: on the whole progress is very slow as the car is taking up too much time :)
Originally posted by THEMP3KID
I won't start an argument, but I highly doubt there are any controllers that would be happy with unregulated voltage...
Please excuse my ignorance.
Wow, you guys kinda opened my eyes I looked at my controller spec sheet ( http://www.zlcd.com/downloads/NL6448AC2006.PDF ) says the supply votage should be 4.75v - 5.0v @ max 1A. I've always used 12v regulated and unregulated (from car). Hmmmm...
I wonder if I've killing it?????????????
hey buddy i m confussed //// i just saw your LCD data sheet
and its a TFT screen LCD... not a 20x4 or 40x4..ect
So where did you connect the 12volt to?
to the Vcc..? and it survived/// ?
Buddy your one LUCKY guy ...
or, we could make a circuit to filter the 12v from car as the sproggy-supplies does
checkout sproggy.com
but when you are at it tearing all the interiors off the car when hiding the signal cable, you might aswell throw in a cable for +12 regulated, 2.5 square millimetres will do, huh?
oh, and use car chassis as ground.
I take that all back. I found the document that was sent to me from earthlcd.com with the LCD. It does infact use +12vcd.
I attached the document.
I've got no answer!
even more reason to use the molex connector...got an easy connection to 5v there...don't listen to the guys telling you to go from the cigarette lighter..ESPECIALLY if it's rated at 5v..
Originally posted by Mastero
PPGT94
so just FYI DONT power the controller with unregulated 12vdc supply..
Mastero
Good call, I agree. I actually ran a wire from the comps. psu to the controller card today
Thanks for the advice.
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
