Results 1 to 5 of 5
Thread: Xenarc causing noise (powering issue)
    Nov 2004
    Ok, so I just got done with installing my Xenarc screen. I am getting a small line noise issue when the screen gets a signal (beit from the AV2 input or the computer). So the noise comes through my speakers only when the LCD gets a signal.
    Now the Xenarc is directly wired into my cigarette lighter (just lopped off the end) and the connection is solid and a good ground as well. It is NOT the comptuer causing the noise as well because even when I didn't have the computer it would make the noise with the AV2 input.
    1. Do I need to give the Xenarc regulated power? I don't think so because it handles this internally -- it must because the cigarette lighter adapter has no electronics in it and they intend you to hook it directly into your car then.
    Thanks, any ideas will help!
    PS: There is also another issue where the AV2 doesn't come on automatically when sensing a signal (if the monitor is in standby) but I'll start another thread on that.
    May 2006
    United Arab Emirates
    I have the same problem with my Xenarc. Wrote to their support and they told me to turn the volume all the way down.
    Aug 2004
    I have the exact same problem! The noise would go away everytime i restart the monitor. Then about 30 seconds later it will start to come back!
    I already turned the volume all the way down to zero! HELP!!!
    Nov 2004
    The volume to zero trick worked for me! Thanks.
    Aug 2004
    I fixed it, i unplugged the speaker wire inside the xenarc!
    Honda Lagreat Carputer Project. Mobile Entertainment
    http://www.mp3car.com/vbulletin/showthread.php?t=33936
    Full Spec for mods check out:
    http://www.hondashowoff.com/profile.php?id=3766
  1. Replies: 19
    Last Post: 05-15-2006, 01:54 PM
  2. Power issue with Xenarc
    By agent4877 in forum LCD/Display
    Last Post: 04-18-2006, 12:10 PM
  3. Powering new Xenarc 7" -Dead Avatar Monitor
    By alexvr1 in forum LCD/Display
    Last Post: 04-18-2006, 03:53 AM
  4. xenarc gain causing RF interferance
    By fishy in forum LCD/Display
    Last Post: 12-30-2004, 05:36 PM
  5. Lilliput causing engin noise
    By eazyrog in forum LCD/Display
    Last Post: 06-07-2004, 08:58 AM
