Results 1 to 10 of 10
Thread: Powering LCD from car?
    Mar 2002
    I'm planning on using a laptop as the basis for my system so I cannot use a floppy drive connector for power to the LCD. If I get a "wide voltage" LCD, will I be able to power it directly from the accessory line from the car battery? If so, that takes care of that problem. However most LCD's I've seen still require 5V for the backlight. Where should I get these 5V from?
    Typing this I had another thought... are parallel LCD's powered from the parallel port or do they need an external power supply too?
    THanks for any help y'all can provide!
    Jan 2002
    I've nearly the same problem. I'm using a notbook, too, but I'm not ready to put it into the car yet.
    But I thought I could get the 5V Source from the IDE Bus, because, the HD's and CD-Roms get it from there, too.
    This is only an idea, I hadn't time to check this out.
    May 2001
    Thessaloniki, Greece
    You could pick up 5V from the PS/2 port of your laptop, OR use a 7805 linear regulator to "make" 5V from your car's 12V electrical system.
    Mar 2002
    Yeah, I brached onto this topic in one of my other threads and decided to pull from the ps/2 port.
    Jan 2002
    Sorry, this could be a new topic, but have you an idea how I could power my NB it's own?
    It has an internal Power Supply, and I'm not sure how I could power it.
    Have I to use one of those DC-DC converters?
    Rob
    Rob is offline
    Maximum Bitrate Rob's Avatar
    Aug 2001
    Missing In Action
    Re: Powering LCD from car?
    They require external power. If you have a game port (some laptops have them) then you can get the power from that. See this site for pin wirings.
    Rob
    And you say people actually pay money for M$ Windows?
    www.mp3mini.co.uk (Does what it says on the URL) www.openclassic.co.uk (The new car, with zero rust!) www.rob-web.co.uk (My other site)
    Total re-design underway: on the whole progress is very slow as the car is taking up too much time :)
    FLAC MP3DUB's Avatar
    Jan 2002
    Chicagoland, IL
    Whats a NB? (in dubspeak its new beetle, and Im guesing thats not what you're aksing about ).
    -Nick
    _____________________________
    Monthly MP3Car Chicago Meets
    www.mp3vw.com Last updated: 07/07/2008
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    Notebook, perhaps?
    Rob
    Mar 2002
    I'm going to guess "notebook"...
    Jan 2002
    yes, sorry, I meant Notebook
    Any ideas anyway?
    First Setup: P133/32MB Ram, 6" TFT, Linux + selfmade Player (SVGA-Lib)...
    Working on: Small Notebook Setup...
