Results 1 to 9 of 9
Thread: Help me plz, my screen lilliput 7'' is blank!
    Mar 2006
    Hi guys,
    Please give me some advice, first of all, I took out a screen from the case and mount it in my dash, and I messed up the ribbon cable (the cable connect from the board to the screen). So I ordered a new one, and it worked fine. But right now, the 4 wires that for the touch screen is no good, then I asked my friend to solder it for me, Also he soldered the power button, so I can turn on and off the screen whenever I want, Everything is look good now, but once I plugged in the power, the screen is just white, I can't even see anything, Also I can't change the mode, like VGA or something like that. Thanks.
    Btw, just in case if the screen is dead. Do you guys think all I need is buy a non-touch screen monitor? Then I can use the touch screen from the lilliput ? thanks.
    here is some pictures of the screen.The one I circle, that is what my friend soldered. thanks.
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    i assume you've tried (for at least 30 mins) to reseat the ribbon cable right?
    Live mp3Car Facebook Chat
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    white screen, usually indicates an incorrectlt seated ribbon cable.
    please do a search for lilliput and white screen.
    Mar 2006
    Quote Originally Posted by Sonicxtacy02
    yes, exactly, and by the way, the ribbon cable. the way that connect to the board is not tight, I tried put something in in to make it tight.
    Mar 2006
    Quote Originally Posted by Enforcer
    Also, I tried to move the cable, and it's still white. Am I soldered anything wrong ?
    Mar 2006
    sighz, I just spent like an hour to move the cable around and it's the same thing, is there any problem beside the ribbon cable ? thanks,
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    could be a fuse on the board that is on the back of the screen.
    there is a thread about it, I think started by JCDilliin
    edit, this one
    Tester Needed! Lilliput White Screen of Death
    Woodbridge, VA
    Blog Entries
    32
    yes test the little rectangular fuse next to the power cord.. least thats where it is on most lilliputs.
    Mar 2006
    hi guy. is this the fuse ? and how can I check it? by the way if it is dead, how can I replace it, sorry for the all newbie questions, but I really need help. thanks
  1. KITT - It had to happen sometime!
    By prefim in forum MediaCar
    Last Post: 08-22-2010, 10:39 PM
  2. Lilliput VGA controller or lcd screen??
    By Mush in forum LCD/Display
    Last Post: 03-22-2005, 04:54 PM
  3. 8" Lilliput screen help please!!
    By cfree in forum Newbie
    Last Post: 03-01-2005, 09:02 PM
  4. Lilliput only uses a portion of the screen
    By gambit32 in forum LCD/Display
    Last Post: 09-06-2004, 01:11 AM
  5. Problems with new lilliput touch screen panel?
    By markc04 in forum LCD/Display
    Last Post: 08-27-2004, 02:38 PM
