Results 1 to 4 of 4
Thread: LQ10DS05 - Is Anything Possible?!?
    Apr 2002
    I've recently taken apart an old Dell Latitude XPi as it stopped working. After much messing around, I've discovered the display is a Sharp LQ10DS05 10.4". The laptop itself is dodgey, it sometimes boots and sometimes sounds a beep code.
    I'm wondering if ANYTHING practical can be done with the LCD, it seems such a waste to throw away a perfectly decent piece of kit. I've attached some photos of the plug on the screen and the socket on the motherboard if it helps.
    I understand it's difficult to get a VGA signal to LCD but can anything else be done with it?
    ANY help or technical info would be much appreciated!
    Regards,
    Alex O'Donnell
    Mar 2002
    you'll need a controller for the LCD to convert a VGA signal from your comp to a digital signal the LCD can understand.
    (www.earthlcd.com but the controllers are expensive)
    birrman54
    FLAC LESLIEx317537's Avatar
    Jan 2002
    Long Island, NY
    Is that a Dual Scan display?
    If so the screen is not worth it.
    I got the Active Matrix version of that screen. The 10.4" TFT lying around here.
    SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
    GPSing - Digital Speedo
    Relocating headunit and extending faceplate
    Button app to Alt-Tab between two programs
    Apr 2002
    Biscuit PC?
    I'm not sure if it's Dual Scan, what's the easiest way of telling?!?
    I was searching for more info on the LCD screen when I came across the range of Advantech Biscuit PCs. Which apparantly have built in LCD support. The screen is mentioned in the description of the PCM-4825/L, unfortunately this page is no longer available but google has a cache of it - http://216.239.51.100/search?q=cache...LQ10DS05&hl=en
    Does anyone has any opinons or experience with these mini motherboards?
    Thanks,
    Alex
