Results 1 to 5 of 5
Thread: LCD works fine on one PC but is dim as hell on my CarPC
    May 2006
    Vineland, NJ
    I got a 6.4" LCD kit off eBay some time ago that was originally sold by earthlcd.com and I am having an odd problem with it. I hooked it up to one of my desktop PCs (powered through a molex connector) and it was working fine. Then I hooked it up to my CarPC and it wouldn't boot completely since the PS couldn't handle the LCD. So I got an old PS that has the switch wired to it and hooked the LCD up to that, but now it is extremely dim, and is only visible if looking at it from a top angle. Any ideas? Thanks in advance for any help you provide.
    May 2006
    in addition to voltage, make sure you are supplying the proper amount of current from your power supply.
    May 2006
    Vineland, NJ
    The switching power supply that I tested is rated for 200w with 7.5amps on the +12 volt rail. I think that should be more than sufficient to run just an LCD. Does the VGA cable itself pass any current? Maybe I will try re-crimping the molex connectors.
    Variable Bitrate Moneyfink's Avatar
    Feb 2005
    S Ohio
    yellow = +12 volts?
    My OLD carputer page
    My NEW carPC
    Via Epia M10000, 512 PC2100, Opus 150, 8" lilly touch, 320 GB 7200 WD Caviar
    May 2006
    Vineland, NJ
    Yea, and I used the ground next to that, although the LCD works without the ground - red on LCD to yellow molex.
  1. Dell Axim x5 as CarPC
    By Genesisfactor in forum The Review Palace
    Last Post: 11-30-2009, 05:58 AM
  2. Lilliput works on home pc but not car PC!!!!!!!!!!
    By lax4321 in forum LCD/Display
    Last Post: 02-24-2007, 06:24 PM
  3. Pocket PC with CarPC
    By dug1967 in forum General Hardware Discussion
    Last Post: 12-03-2005, 06:30 PM
  4. Car Environment Temperature vs LCD screen, PC??
    By dekodan in forum General Hardware Discussion
    Last Post: 08-01-2001, 03:46 PM
  5. Laptop LCD vs Flat Panel LCD (PC)
    By Nads O'Hair in forum LCD/Display
    Last Post: 05-02-2001, 09:58 PM
