Results 1 to 4 of 4
Thread: Need help with fuse for a monitor
    Maximum Bitrate Zebelkhan's Avatar
    Dec 2004
    Bay Area, CA
    I know this is not carputer related but since I cannot get help for this from the manufacturer I thought I should ask here and hope someone can give me the answer.
    I have a 15 inch LCD for my desktop at home that just died and I have traced the problem to its fuse. It has one of those tiny "soldered on" fuses simillar to the ones on Lilliput. I cannot get the OEM fuse so I am going to just use a regular fuse and holder and solder it in its place.
    I know it is 12 volt and I know it is 2 Amp but what I don't know is if I should use a "slow blow/burn" or "fast blow/burn" for this.
    This is a Sylvania monitor made by Princeton Graphics with following info:
    Model #: PD-70FA
    Part #: 21AP1514DSM
    Serial #: 8RCC1403152
    Manufacture date: Apr 2002
    Thanks in advance for any help.
    Compaq Evo D510 e-PC - P4 2.0 - 512M RAM - 120G 3.5 HD - 7" Xenarc 700TSV - DSATX fitted nicely inside the PC case
    Oct 2004
    NY
    I would try a fast one first... if it lives then leave it... if it blows try a slow blow.... if that burns then there is a problem.... it's not common for a fuse like that to blow....
    Dec 2004
    Bay Area, CA
    Quote Originally Posted by turbocad6
    I don't know why I didn't think of that! That is good advice.
    Strangely enough I think it had something to do with me testing my old carputer at home. Don't know why or how but ever since I took my EPIA mini itx carputer apart to clean and then put the mobo back but using insulated legs (instead of original metal ones) I have had nothing but trouble. I have lost two laptop drives that went dead on me (They stopped spinning) and then this display went dead a few minutes after I hooked it up to the carputer eventhough I have a KVM switch in between. It may have somehow been pulling ground through the display connection. Don't really know.
    Dec 2004
    Bay Area, CA
    Just a quick update, got a fast blow Pico fuse and soldered in and the problem has been solved....
    Thanks for all your help.
  1. New ebay LCD
    By shahin_xp in forum LCD/Display
    Last Post: 12-03-2006, 04:21 PM
  2. Headrest Monitor or Dash Monitor
    By BIzFlawless in forum Classified Archive
    Last Post: 01-28-2006, 04:16 AM
  3. Replies: 1
    Last Post: 03-23-2005, 12:41 PM
  4. FA: Lilliput Touchscreen Monitor - $200 + $15
    By AJ Quick in forum Classified Archive
    Last Post: 08-04-2004, 12:20 PM
  5. Running windows with no monitor?
    By BLACKOUT in forum General Hardware Discussion
    Last Post: 03-14-2001, 11:56 AM
