Im having the same problem. Been at it for two night and still no luck. I've installed and reinstalled numerous times with different options( but there aren't that many) and still no luck.
After many attempts I cannnot seem to get the touchscreen to work on my in-dash lilliput. I have installed both old and new drivers and nothing works. The computer shows the touchscreen as a USB touchscreen controller but the touchkit does not pick it up on any com ports it seems. I took apart the screen to check for loose or damaged connections and all looks well. Any ideas? Thanks in advance
that makes 3 of us.. i just got my monitor friday morning and no luck yet...
3.06 P4/1.5GB DDR/200HD/1x 8" Lilliput TSV | GPS | 5.1 Surround | Bluetooth | 12 Sec. Boot Time | Wi-Fi |
*raises hand* same problem for me.. tried it out tonight and it won't calibrate at all!
this is sad...four people and still no help...guess I should just stick to turbos
the drivers that came with my in-dash did not work, but i got the latest ones from http://www.egalax.com/ and they work...until i turn the pc off, then on the next restart touch does not work.
same problem with my TM-868.....sees the USB connector when I plug it in, makes "ding" noise....registers it as a "unknown device" and thats about all that happens. Funny thing is, when I bough it, it worked just fine and it slowly stopped functioning...Im at a loss, so im about to throw this thing in the trash![]()
MECA Car Audio Judge
wow. this started happening about a week ago. friggin thing is garbage.Originally Posted by snoopdan
i figured out my problem! i was tapping the x to calibrate the lcd.. but you're supposed to hold it down! haha i'm an idiot!
Hehe, that's funny. At least you got it workingOriginally Posted by hornyleprechaun
Installed.
-GPSSecure- - GPS Tracking
