Page 9 of 22 FirstFirst 12345678910111213141516171819 ... LastLast
Results 81 to 90 of 216
Thread: Transflective Upgrade - THE RESULTS
  1. #81
    Newbie BFarm's Avatar
    Sep 2005
    Annapolis, MD
    Zip-Lock: I am also interested to hear what type of panel will be used for the mp3car store version.
    2005 Subaru Impreza WRX STi, OBP/Silver
    Carputer currently in development stage.
  2. #82
    Variable Bitrate nameeri's Avatar
    Mar 2006
    SoCal
    Quote Originally Posted by Zip-Lock
    We will soon have something up on the store. Itís at least three weeks off before we will have anything ready to ship.
    The price wonít be cheep; it will be about $599 for a 7Ē LCD sunlight readable panel with touch screen. Just to clarify, that wonít be a panel upgrade program, but rather a new panel that has been modified. All units will come with a 90 day warranty against defects.
    More details are to follow.
    I like where this is going... Googadee Gogadeee Goo-Ga-Dee Alllllright!
    Civiputer: Dont have one anymore, but here is what is used to be!
  3. #83
    Raw Wave kickercivic1's Avatar
    May 2003
    Florida
    If its Xenarc that will be upgraded then i am most likely in for one.
  4. #84
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    Also what is the native resolution of the screen (and if support other resolution which ones)
    Thanatos.
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
  5. #85
    Elsewhere
    My question is if this upgrde can be performed on the in-dash units, namely the Xenarc 700IDT that I want so badly....
    How about the Wiki?
  6. #86
    Aug 1999
    Washington D.C.
    Quote Originally Posted by DarquePervert
    We have plans to sell new in dash monitors with the upgrade. These things take time and am personally working on it expeditiously, but it will still take a matter of weeks.
    The problem with upgrading products that people already own is the upgrade process will take a long time, up to six weeks. That could be expedited if you where willing to accept a refurbished LCD panel instead of the one that came with your monitor. Also there are unanswered questions such as will it fit back into a given in dash monitor housing after the upgrade has been done. There are also issues with the touchscreen and retrofitting a new touchscreen controller into an existing housing where it might not fit.
  7. #87
    Aug 1999
    Washington D.C.
    Quote Originally Posted by kickercivic1
    The first batch will be Lilliputs. It remains to be seen if they will fit back in to their housings or not in which case they will be sold as open frame LCDs.
    Also, the branding on the outside of the monitor doesnít matter that much. All of them are using LCD panels from major companies, like Hitachi, Panasonic or AU. All they do is make a controller board for it and a plastic housing. That said I find the Lilliput controller boards to be of higher quality so thatís why there were chosen. The Lillput controllers are also more concise (less complex = more reliable), they include the backlight inverter, VGA controller, and touchscreen all on one board, rather then Xenarc who uses three PCB boards for those same factions with double sided tape to hold everything together.
  8. #88
    May 2003
    Florida
    WOw zip from what i read on this forums lillput sux. Mine stop working in 2 weeks. I dont know about you i like my gain always works like it should and never screws up.. Anyways if you do xenarc for $600 let me know.
  9. #89
    FLAC coucouillu's Avatar
    Nov 2004
    FRANCE
    Also, the branding on the outside of the monitor doesn’t matter that much. All of them are using LCD panels from major companies, like Hitachi, Panasonic or AU. All they do is make a controller board for it and a plastic housing. That said I find the Lilliput controller boards to be of higher quality so that’s why there were chosen. The Lillput controllers are also more concise (less complex = more reliable), they include the backlight inverter, VGA controller, and touchscreen all on one board, rather then Xenarc who uses three PCB boards for those same factions with double sided take to hold everything together.
    Zip lock ..
    I have a lot of experience with Lilliput Hitachi indash screen. I have Three of them and have hacked them...(look my signature INDASH SCREEN V2)
    Tell me if you want to share experience.
  10. #90
    Oct 2004
    NY
    lilliputs aren't really worse than the xenarcs, they seem to be more problematic here because they are also much more widely used... if all other things are equal, if liliputs average 3:1 then of couse the lillis will look like they have 3 times as many problems....
    add to that the fact that, because the lillis are cheaper, there much more likely to be taken apart & screwed with, making them seem even more problematic.... the guys that go out & buy the most expensive screen will either avoid chopping it up, or do so a bit more carefully... I don't think lilli's deserve there bad rep...
  1. Transreflective Upgrade - The Review
    By nameeri in forum LCD/Display
    Last Post: 06-07-2006, 02:35 PM
  2. Replies: 131
    Last Post: 05-18-2006, 10:34 AM
  3. Transflective Upgrade available who wants it?
    By ovsims in forum LCD/Display
    Last Post: 04-23-2006, 11:57 PM
  4. LCD Backlight Upgrade
    By jcdillin in forum LCD/Display
    Last Post: 10-09-2005, 01:01 AM
  5. Replies: 7
    Last Post: 09-13-2005, 06:00 PM
