Page 2 of 6 FirstFirst 123456 LastLast
Results 11 to 20 of 55
Thread: 800x600 stopped working! Help Please! Ex-Audio TS LCD
  1. #11
    Aug 2005
    actually when i changed the refresh rate to 75,72,70 and 60 the screen would work but only after swapping from a crt that i made the changes from, however when restarted to see if the screen would boot up again it did not. then i changed it all the way down to 56 and it starts and restarts without a hitch. hopefully this setting will hold strong until i put everything back in my car.
  2. #12
    Apr 2007
    Quote Originally Posted by 2k1Toaster View Post
    talk about bringing up a repressed memory!
    here's my solution but you aren't going to like it: change resolutions.
    basically i hooked up a CRT to my carPC, and changed the resolution to 1024x768 and then plugged the ex-audio back in. then make sure you set your frontend to the new settings. for instance i use RR so i changed the ini file to show width and such to 1024x768. also in rrconfig. because the frontend autoscales everything, it looks the same, but it is running at a different resolution . only difference is in windows everything is itty bitty but still readable.
    doesn't bother me too much anymore but in the back of my mind it still haunts me...
    sorry to bear bad news but at least youll get a picture now.
    oh and btw, my typing sucks because im on my phone.
    God i'm having the same f'in problem with my lilli 702 hr /via s3. Accidently hit the auto-adjust (which is placed nicely next to the brightness adjust) and it freaked out. Now I can get to every mode except any of the 800x600 (which of course is the one i want).
    Tried everything.
    HEEEEEEEEEEEEEELP
    Also, if you can tell me where in RR you were able to scale to 1024, it would be appreciated. I found the setting, but changing it doesn't seem to get RR to scale anything. Can you drop me a PM?
  3. #13
    Apr 2007
    Quote Originally Posted by jetblack5spd View Post
    How'd you change it to 56? In windows i can't go any lower than 60.
  4. #14
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by mscappa View Post
    Tried everything.
    HEEEEEEEEEEEEEELP
    In RRConfig make sure it is set to Default as the size, and then on your skin change the general ini file "Showwidth" and "showheight" to 1024 and 768 repsectively.
    1.9in x 2.9in -- 47mm x 73mm
  5. #15
    Low Bitrate maniaxzero's Avatar
    Apr 2005
    Queens, NYC
    damn i got the same screen but its made by lilliput. So far 800x600 is working pretty good. Keeping my fingers crossed.
    I do have a problem with the touchscreen though. Sometimes if i turn off the monitor and turn it back on, the touchscreen would not work. The mouse cursor would be stuck at the bottom right corner when i try to touch anywhere. If i connect a mouse, the mouse works fine while touchscreen is still acting up.
    My only solution is to wait 5-10 min and it seems to fix itself. Or sometimes i just restart the pc a few times and it works. Definitely very strange.
  6. #16
    Mar 2006
    Quote Originally Posted by maniaxzero View Post
    Yeah when I made this thread a year ago, I had no idea what a "Lilliput" was pretty much let alone that they were all the same.
    I think I f'ed it up though. So if you are good to it, dont expect problems. Just odnt plug in the power while the VGA is sending a signal I suppose.
    As per your intermittant touch problem, how are the usb power settings setup?
  7. #17
    Apr 2005
    Queens, NYC
    I checked the ALL the usb power settings and it's not in power save mode or anything of that nature.
    The touchscreen USB is plugged in directly on the motherboard.
  8. #18
    Apr 2005
    Queens, NYC
    I think i found the solution to the touchscreen problem.
    I just did a 25 points linearization calibration and it seems like the problem went away.
    I tried restarting, standby, turning screen on/off multiple times. I cannot replicate the problem. I hope this is a permanent fix.
    Maybe this will help some ppl in the future.
    Update: the fix didnt work. The screen is having the same problem again. =/
  9. #19
    Apr 2007
    thank you!
  10. #20
    Dec 2005
    Raleigh, NC
    I hate to resurrect an old thread, but, has this been resolved? I'm planning on buying an EBY701 and I want to make sure it supports 800x480 or 848x480.
  1. still cant get audio working!
    By djmickyg in forum PhoneControl
    Last Post: 07-23-2005, 09:51 PM
  2. Audio problems, Epia Sound, and FAQ stuff
    By gothate in forum Newbie
    Last Post: 06-16-2005, 05:04 PM
  3. COM port stopped working... need help!
    By chris in forum General Hardware Discussion
    Last Post: 02-17-2001, 12:39 AM
  4. Can't Get 40x4 LCD working on PC
    By Squeeky in forum General Hardware Discussion
    Last Post: 02-13-2001, 04:31 PM
  5. 2 lines not working for LCD
    By Saab in forum General Hardware Discussion
    Last Post: 08-10-2000, 11:05 PM
