Page 4 of 6 FirstFirst 123456 LastLast
Results 31 to 40 of 55
Thread: 800x600 stopped working! Help Please! Ex-Audio TS LCD
  1. #31
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by voldaran View Post
    Could someone explain this?
    If you have the monitor hooked up to your PC and the PC on meaning sending a video signal down the VGA, dont touch the power on the monitor. Dont plug it in, or unplug it.
    1.9in x 2.9in -- 47mm x 73mm
  2. #32
    Jun 2007
    Quote Originally Posted by 2k1Toaster View Post
    Lets say... Hypothetically... I did... er, My FRIEND did this... what might happen?
    This is the first I'm hearing about this.
    Thanks!
    V.
  3. #33
    Mar 2006
    Thanks!
    V.
    Well it is not supposed to do anything. But sometimes these cheap screens just dont like power surges. So it might do what happened to mine. Burn out a chip, and no more 800x600 resolution.
  4. #34
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    So, got my lilli 701 working on 800x480 and that damned auto adjusting button won't "f" it up anymore!
    I hooked up a crt (so I could mess with settings without it going black) and fished around a bit with nvidia's config screens. I clicked "hide modes this monitor cannot display".
    The only mode left was 800x480 at 75 hz.
    I added a custom resolution at these settings in the nvidia config panel and..........
    Success!
    The only strange thing is that the Lilli OSD says it's 640x480, but everything displays as 800x480. Weird. Also, 960x800 came up as 800x600 on the osd. Weird-er.
    Now I can hit that annoying little auto adjust button all I want and all it does is center the display as it's supposed to without giving the monitor an aneurysm.
    I think what happens is when the monitor tries to "auto adjust" on a resolution off even a bit from what it wants, it says "I don't know what to do with this" and just sets "out of range" and a black screen. Basically, it says "I don't know what you want, do it yourself".
    Get the settings right and it says "ok, I know this" and does the centering like it's supposed too.
    That's it in laymans terms.
    Not saying it will work for everyone, but it does for me.
    Good luck all.
    BJ
    Leonardo Da Vinci
  5. #35
    Apr 2007
    Quote Originally Posted by greatwhite View Post
    Success!
    Good luck all.
    BJ
    congrats on the success! what sort of mobo/video card are you running?
  6. #36
    May 2007
    Quote Originally Posted by mscappa View Post
    Mobo: dell (intel?)
    Video card: Nvidia, mx440 chip. It's an older agp card I had lying around. Works fine for the car though. I'm looking to switch to a half profile dual head card.
    Leonardo Da Vinci
  7. #37
    Low Bitrate sviyer's Avatar
    Oct 2006
    I too faced the same problem on my lilliput today. Touched the auto adjust by mistake and now i am sitting with the "out of range" message!!
    But stangely when i plug my laptop running on the 800 X 600 , it displays. Only when i plug the car pc in, it displays the "out of range" message.
    Does that mean the video chip is safe? Will reinstalling the OS in my carpc solve the problem?
    Honda City
  8. #38
    Apr 2007
    Quote Originally Posted by sviyer View Post
    for what its worth, I got rid of my jetway board and went to an ibase system. I can press the auto-adjust all I want now and it seems to work fine.
    I presume its because the jetway/s3 chipset isn't quite pushing out the exact refresh rate it says, and the lilli is freaking out because of it.
  9. #39
    Newbie aleshu's Avatar
    Oct 2006
    Buenos Aires, AR
    Angry
    Hi. Same problem here with my Lilli EBY701. It worked OK for 7 months using 800x600 @ 60 Hz, and just about an hour ago I pressed the Auto Adjust button and got an awfull OUT OF RANGE sign.
    These people at Lilliput don't f'in test their displays??
    I tried reseting via the OSK menu, but seems it only applies to the current resolution and frequency. All the others resolutions work OK.
    I'm now working at 800x600 @ 75 Hz and it looks OK, but I really need to recover the 60 Hz frequency, not to speak that I'm more scared of pressing again that button that I am of the little chinesse kid in The Grudge
    I seems that the screen internally stores horiz and vert clocks set by this button and once it's configuration goes out of range it can never go back or be reseted.
    Any ideas of how to reset ALL modes and frequencies at once?
    Have any of you guys came out with a real solution?
    Thank you!
  10. #40
    Dec 2005
    Raleigh, NC
    Or does anyone know how to disable that button so if you press it nothing happens?
    Nick - 08 GG Element
    Custom 3D-CAD Design, Reverse Engineering and Fabrication
  1. still cant get audio working!
    By djmickyg in forum PhoneControl
    Last Post: 07-23-2005, 09:51 PM
  2. Audio problems, Epia Sound, and FAQ stuff
    By gothate in forum Newbie
    Last Post: 06-16-2005, 05:04 PM
  3. COM port stopped working... need help!
    By chris in forum General Hardware Discussion
    Last Post: 02-17-2001, 12:39 AM
  4. Can't Get 40x4 LCD working on PC
    By Squeeky in forum General Hardware Discussion
    Last Post: 02-13-2001, 04:31 PM
  5. 2 lines not working for LCD
    By Saab in forum General Hardware Discussion
    Last Post: 08-10-2000, 11:05 PM
