Okay, you connect your voltage source to the VCC pin... and ground it to the "ground pin".. I don't know what voltage it needs (probably 5v).
Then you connect each of the AC output pins to the EL strip wherever is most convienient... if possible I think you'll get more even lighting if you connect the AC output to opposite sides of the EL strip.
Good Luck,
-Miles
LinkBack URL
About LinkBacks
