assuming you have all the cables hooked up the right way....
the jumpers were correct from the factory...
did you hook up the power connection the right way? the pin should be 12 v and the sleeve should be ground....
press and hold the on/off buttton onthe osd for 3 seconds... that should turn on the screen... if you have the led hooked up, it will remain off until you hold the on/off switch for the 3 seconds, then it will go to orange, and it will be green when the screen is operating.
also, you should do the hirose cable fix. change the wiring so that it pulls the info from the higher number data signals... there is a thread in the lcd forum about it...
~mike
edit... here is the other thread
LinkBack URL
About LinkBacks
