Have you tried plugging it into a different USB port? Have you taken the thing apart?
So, I set up all my software and have my laptop ready to install. I was doing some final steps and I realized that the touchscreen Lilliput is no longer touchscreen!
Its connected via the VGA cable and the USB port. When I disconnect the USB, the screen dims. When I open the touchit software it shows no connectors. Ive removed and reinstalled all the software with no joy. Anyone have any ideas? It just stopped and I have no idea why! Im all ears.
1.9in x 2.9in -- 47mm x 73mm
No, I ave not taken it apart, (the lilliput) and yes I have tried it in a different port. I also installed the updated drivers from the webpage here. I cannot even get the 4 point calibration test to come up. Is there anyway I can fix this?
Also the touchit software shows NO devices and willnot allow me to manually add the drivers. When I click on "have disk" and point to the USB drivers it says that it is not for my device. Are there any alternate ways to connect this touchscreen besides USB? A connector or converter I can buy?
I FIXED IT!!!!!!
Sorry just treally excited. 5urns out my wife disconnected my wires and such to clean and when she reconnected everything she put it in wrong and bent a pin. Fix the pin and viola! Had to reinstall the drivers, but it worked! Thanks Toaster for the insite.
