That's wacky, but cool....
Hi there!
This is my first post here, although I've been reading mp3car.com for long time ... I usually participate in a Spanish forum www.solocarputer.com and I just wanted to say hello to everyone (cool forum and super-useful information, guys!) and to present my little experiment here.
When I first thought about installing a carpc, I didn't like the idea of having a little (7" or 8") monitor and tried to install a normal desktop TFT, but failed miserably; there was no room to place such a thing, it would be _very_ notorious from the outside, and it wouldn't even look good from inside.
The solution proposed was very simple: multiply
At first it was intended to be used as a simple multi-monitor carpc; but now I'm into using it to be able to run both Linux and Windoze at the same time, using a spare laptop.
More info, pics, and some videos in
http://www.solocarputer.com/phpbb2/viewtopic.php?t=4991
and
http://www.solocarputer.com/phpbb2/viewtopic.php?t=1408
( Again, thanks to everyone for your contribution to the "carpc science")
Cheers!
Loco!
Nice one, but a little low for TS, no?
Dat's whack, yo!
So far:
M10000 Nehemiah, 1Gb RAM, Opus 90w PS, Buffalo Tech WLI2-USB2-G54, 160 Gb HDD, GlobalSat BU-353 GPS, iGuidance, Zippy EL-610, Panasonic CW8123B Slim Slot CDRW/DVD, 10" Lilliput, Sony XA-300, Sony CDX-MP30 Head, OBD-II
Ho, I have already thought about that , but you did it before...![]()
can't wait to see the final instal and see it working.
when shifting, how do you not hit the bottom screen with your knuckles?
get a pickup truck shifter. And if that isn't long enough, get one of the shifter from a semi.Originally Posted by BoraXP
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
longer? you want a shorter shifter so that it goes under the lcd. A longer one will just make you hit it sooner but at a higher heightOriginally Posted by MatrixPC
Alex
90 300zx twinturbo conversion
Epia C3, 512 ram, syntax mobo, 80 gig WD, Mediacar, GPS w/Routis, all behind drivers seat, 7in Lcd Lilliput VGA with Touch, wireless adapter for stumbling, Consult ODB1 adapter and data scanner.
Even with the inverted screen a little bit angled, I have no problems to change gears. I have to be careful when opening and closing it, but that's ok for me![]()
*****/5 stars for innovation. Great Job!
Sound StageEclipse|MTX|Infinity
