LCD size for double DIN ???
Hey,
I'm looking for indash touchscreen for my SUV. Easiest would be to just fit the current double din- what screen options do I have? I've seen a few 6.4 out there... does 7" require modification? I am fine with creating mounting and fabricating, but I'd like to keep the current opening if possible. What brands for touch in that size do you recommend?
Thanks, D
The Redant that dscustoms sells is only a 1/4" too tall without its casing for a double din slot. If time permits, I'm going to try to cram it in there this weekend. I should only have to make a small cut to the top of the double din slot so that the top of the screen can slide up there.
If you want a touchscreen, I've heard that someone talked to a company that would make one for about $250 that will fit the Redant.
Isn't the redant 7" tv in; ie no rgb connector from my computer?
Also, who makes that touch screen?
Right, it's not a VGA LCD. Noonyb said he found a company that would make the touchscreen, but never revealed who it was. Must be a *secret*.
no one asked everyone just said it was to high. The company was magic touch. I havent ordered one yet im still trying to decide if its worth it. I can give you the guys name i talked to if you want it. He said the tolerances will be +/- 0.15 of an inch. As for fitting in a double din it will in my truck just have to make a custom case for it.
price on the touch screen? and what type is it?
any other suggestions for vga and touch screen? 6.4 preferred, or 8.4
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
