Results 1 to 10 of 11
Thread: Dynamix 816 Widescreen
    Feb 2006
    Mississauga, Ont Canada
    Question Dynamix 816 Widescreen
    I was looking at getting this monitor for my setup. http://dynamixcomputers.com/dynamix_...n_monitor.html Does anyone have this monitor? If so, have there been any noticeable problems with it? I've tried searching and can't seem to find any info on this model...
    Elsewhere
    IT's a newer model, so there aren't very many people who have one. If you do get one, you may very well be one of the first members to do so.
    How about the Wiki?
    Jul 2006
    Hey,
    Did you end up getting the dynamix 816? If you did or if there is someone else that has it could they tell me how it performs. I'm thinking about maybe getting it. How does it compare to some of the other touch screens out there? Also does it have an auto power on feature? Any comments about it would be great,
    James
    Feb 2006
    I did end up getting the screen. It works great. I have no complaints whatsoever. It does auto start on pc startup. I have not taken it apart as yet. I'm still figuring out where I want to mount the screen in my car. I will keep you posted. I'm just about to start a work log thread.
    Variable Bitrate AllThingsEnd's Avatar
    Jan 2006
    Ft. Bliss, TX
    can you post some pics of how the screen is? also hows the viewing angle and how is it with glare
    [::::::::::] 100% - Planning
    [::::::::::] 80% - Computer
    [::::::::::] 0% - Fabbing
    CarPC:
    SP13000 / 120GB SATA 2.5" / 512MB DDR
    8" Innovatek TS / Globalsat BU-353 / Engenius EUB-362 EXT
    Slot load DVDRW / PS3 Wireless Keyboard
    Dec 2005
    Raleigh, NC
    When you get it apart can you also take measurements of the LCD unit for both physical and viewable dimensions? I have room for a double din (with a little extra space) and I know it will be tight, but I wanted to find out how tight before I bought one.
    Edit:
    Sorry, found the dimensions in
    My E39 Bezel Attempt
    Bezel: 189mm x 120mm
    Viewable: 178mm x 108mm
    Aug 2006
    Pakistan
    Quote Originally Posted by pack3twhore View Post
    pack3twhore, does this unit have auto switch to rearview functionality ?
    Jan 2003
    It's should be the same as the Tview and PRovision 8" widescreen in the review section of the forum
    Feb 2006
    Quote Originally Posted by AllThingsEnd View Post
    I will post some pics very soon. Sorry, I still have not found a perminant location in my car. My temp location I will post in the next few days.
    Quote Originally Posted by aghazi View Post
    It will default VGA first. You have to manually switch to the RCA inputs if you want them to appear first for a camara. Not that much of a problem for me. I don't plan on adding a camara until much later in my project. Comes with a remote so if you decide to remove your buttons you can use the remote instead.
    Banned Motorcity's Avatar
    Apr 2003
    Detroit, MI
    ....Comes with a remote so if you decide to remove your buttons you can use the remote instead.
    And just how do you plan to pull this off???
    If you remove the button board, say for a custom bezel, you will loose the IR sensor that the remote sends the signals to.
  1. any feedback info. on Dynamix 7" VGA Touch Screen TFT ???
    By xtreamvette in forum LCD/Display
    Last Post: 04-22-2007, 04:19 PM
  2. LinITX Touchscreen 8" NON widescreen LCD
    By DodgeCummins in forum LCD/Display
    Last Post: 08-04-2005, 03:24 PM
  3. Dynamix 706 dimensions
    By patdpolishpower in forum LCD/Display
    Last Post: 03-16-2005, 07:04 PM
  4. How do I get widescreen resolution
    By Nokia6600 in forum Newbie
    Last Post: 03-18-2004, 08:39 PM
  5. Widescreen LCD...
    By Pharacyde in forum LCD/Display
    Last Post: 10-19-2001, 03:31 PM
