Originally Posted by ric355
I'm not a coder Ric but if you have any suggestions to Konfoo![]()
to both of you ...
Terran
Yes, the only place I had a problem was on resume - it worked properly from a cold boot, so the app is only launched after resume for my needs. I also never cared about the window being visible because my screen doesn't come on automatically and chances are I hadn't even switched it on by the time the app had been killed.Originally Posted by ccsnet
EZSync - http://www.richmet.com/ezsync
to both of you ...
Terran
Here try this. Timer disabled.
Cheers will do... wonderd what the timer was for... timer from start of boot ?Originally Posted by konfoo
Will try first thing.... btw Konfoo... where are you ? I'm in the UK ... you ?
Terran
Timer to check the process periodically. Since the process is killed after it is launched it is kind of moot to use anyway, since detection will always fail and it will be fired every [timer] interval...
I'm in socal.
Wheres that ( sorry I'm been dense ) ?Originally Posted by konfoo
Terran
No worries. Its' southern California - Orange County.![]()
Konfoo... looks like that did it.... please accept this virtual beer ( or equiv as thanks )...... any body else that follows me please also say thanks - Konfoo has spent his time to help us out.
Terran
Good deal![]()
First of all thanx for the mayor problem fix.
second: I set the [mode] to mode 3, but it didn't hide the program i relaunched?
any ID?
