Being a bit snarky aren't we? Just because they're running a closed setup of CE doesn't make them not a computer. Newest ones even play DiVX inaddtion to HDD library music.
But since you insist...
Infill G4.
http://www.infill.co.kr/product/g4_style.asp
Even the Infill T3 is 2 DIN... 1DIN flip-out screen and 1DIN CPU, etc.
You must only be thinking mini-ITX or something, because that is too large. Think nano with a different heat sink.
P.S. Another board member has managed to mount 95% of his project in 2DIN in a 2005/6 Mustang GT using a mini-ITX board.
Jan Bennett
Nope... not in the member's custom job. I don't believe it has internal amps, however, I think it would less of an issue with a nano-ITX board. The space savings would help to make packaging alot easier. And worst case scenario, you could always use a 1.8" HDD instead of a 2.5".
The Infill does have internal amps I believe...
Is this a good company to do business with? I've left several messages at their 847 number, as well as a couple of emails with pre-sales questions, and nobody has gotten back to me.
I'll give them the benefit of the doubt that they are small and could be out-of-town on business.
I really want to purchase this double-din screen, but don't want to risk the $650 if they are not totally legit.
I've searched the forums and have not found anything bad about this company, but just want to be sure.
Thanks in advance....
Jarred
A few considerations maybe. 2 single DIN, one of which appears to be transflective and 2 double DIN, one of which appears to be transflective.
http://www.zenec.com/en_flash/index_flamonic.html
ZEM-W800DVD
1 DIN DVD Tuner with 7“/16:9 Widescreen TFT-LCD Active Matrix Monitor with integrated RDS Tuner
Multimedia in your dashboard - ZENEC's ZEM-W800DVD AV center is suit-able for installation in any 1-DIN radio bay. A high-resolution TFT monitor emerges at the touch of a button to display motion pictures in high-definition ZENEC quality. Listen to the radio, play CDs or MP3 audio files, watch DVD movies * ZEM-W800DVD is a versatile control center for your mobile entertainment system. The shockproof multi-format precision disc transport mechanism recognizes and plays CDs, VCDs, SVCDs, CD-R/RWs, compressed audio formats such as MP3 (with ID-3 Tag support) and WMA, as well as standard video formats such as DVD, DVD-R/RW, DVD+R/RW; of course, NTSC and PAL video source formats are both supported as well.
CD/DVD/MP3/WMA Features
DVD drive with electrical and mechanical anti-shock system
supports MP3 (ID3-Tags), CD, VCD, SVCD, CD-R/RW, DVD, DVD-R/RW, DVD+R/RW, DVD-MP3, WMA, JPEG, Picture CD
PAL/NTSC-compatible
Regional Code 2
graphical user interface, on-screen display
Display
motorized 7“/16:9 TFT LCD Active Matrix display
high resolution: 1440 (W) x 234 (H) pixels
generous viewing angles: left-right > 65°; above > 65°; below > 40°
300:1 contrast
Normal, Full and Wide picture aspect selection motorized adjustment of viewing angle with memory function
LC-panel protected against mechanical wear
automatic dimmer control
Tuner
AM-FM tuner with RDS
30 station presets: 18 FM and 12 AM
Audio
integrated 4 x 45 watts digital power amp
integrated Dolby Digital and Pro Logic II decoder
various DSP sound effects (Pro Logic II)
various audio EQ controls
A/V Connections
2 video outputs (RCA)
2 video inputs
1 video input (RCA) for rear view camera
analog 5.1 RCA audio outputs
2 channel preout rear (dual-zone)
Additional Features
additional Dot-Matrix LC-Display featuring blue illuminated segments with high contrast
Rotary volume control
multifunction stick for simple menu navigation
dual zone function
Tel. Mute
ISO connectors for power supply and speaker outputs
2 IR remote controls (front and rear) included
ZEM-W700DMM (Transflective?)
1 DIN 7“/16:9 Widescreen TFT-LCD Active Matrix Monitor with integrated RDS Tuner and TV Tuner
Multimedia in your dashboard - ZENEC's ZEM-W700DMM AV receiver is suitable for installation in any 1-DIN radio bay. A high-resolution TFT monitor emerges at the touch of a button to display motion pictures in high-definition ZENEC quality. The ZEM-W700DMM lets you enjoy radio, control CD and DVD changers and experience movies on the road. The receiver supports a wide range of AV sources: CD or DVD changers, cameras, etc. ZEM-W700DMM uses a newly-developed A-grade LCD panel with anan tireflective coating that enhances the contrast - a useful feature in extremely bright surroundings.
Display
motorized 7“/16:9 TFT LCD Active Matrix Display
Normal and Full picture aspect selection
horizontal angle of motorized display adjustable in three steps
intelligent dimmer control
RDS Tuner
automatic station search
TV Tuner
4-CH Diversity TV-Tuner
Audio
integrated 4 x 40 watts power amp
A/V Connections
1 video output (RCA)
2 video inputs
4 channel preout (front + rear)
1 AUX In
Additional Features
Sanyo bus control for external CD/DVD changer
Tel. Mute
ISO connector for power supply and speaker outputs
IR remote control included
ZEM-W600DVD
2 DIN DVD Tuner with 6.5“/16:9 Widescreen TFT-LCD Active Matrix Monitor with integrated RDS Tuner
Multimedia in the dashboard - ZENEC’s ZEM-W600DVD is suitable for installation in cars with 2-DIN radio bays. Listen to the radio, play CDs or MP3 audio files, watch DVD movies - ZENEC multimedia DVD tuner is a versatile control center for your mobile entertainment system. ZENEC’s ZEM-W600DVD supports a wide range of AV sources. The shockproof multi-format precision disc drive plays CDs, CD-R/RWs, VCDs, SVCDs, DVDs, DVD-R/RWs, DVD+R/RWs, MP3-Files, WMA-Files, JPEGs and Picture CDs ; NTSC and PAL video source formats are both supported as well. The ZEM-W600DVD lets you experience movies on the road: A high-resolution TFT monitor emerges at the touch of a button to display motion pictures in high-definition ZENEC quality.
supports CD, VCD, SVCD, CD-R/RW, DVD, DVD-R/RW, DVD+R/RW, MP3, DVD-MP3, WMA, JPEG and Picture CD
ID3-tag support
Regional Code 2
integrated Dolby Digital and Pro Logic II decoders
electrical (ESP) and mechanical antishock system
TFT-LCD Display
fully motorized 6.5“/16:9 widescreen TFT-LCD active matrix display
very high resolution of 1220 x 234 pixels
generous viewing angles: left-right > 60°; above > 30°; below > 60°
viewing angle adjustable (vertical)
RDS Tuner
AM-FM tuner with RDS and EON
36 station presets (18 FM, 18 AM)
BSM function (Best Station Memory)
A/V Connections
1 A/V input
1 video input
1 switched A/V input (Mono)
1 video output
4 channel preouts and subout
Additional Features
PAL/NTSC-compatible
graphical user interface with on-screen display (OSD)
Tel. Mute
plastic housings with scratch-resistant rubberized surface
ZEM-W600DDMM (Transflective?)
2 DIN 7“/16:9 Widescreen TFT-LCD Active Matrix Monitor with integrated RDS Tuner and TV Tuner
Multimedia in the dashboard - ZENEC’s ZEM-W600DDMM is suitable for installation in cars with 2-DIN radio bays. The ZEM-W600DDMM lets you enjoy radio, control CD and DVD changers and experience movies on the road. The receiver support a wide range of AV sources: CD or DVD changers, cameras, etc. The ZEM-W600DDMM uses a newly-developed A-grade LCD panel with antireflective coating that enhances the contrast - a useful feature especially in extremely bright surroundings.
TFT-LCD Display
7“/16:9 widescreen TFT-LCD active matrix display
very high resolution of 1440 x 234 pixels
RDS Tuner
30 station presets (18 FM, 12 AM)
BSM-function (Best Station Memory)
TV Tuner
integrated 1 channel TV tuner (Mono)
A/V Connections
2 A/V inputs
2 video inputs
1 video output
1 RGB port
4 channel preouts
Additional Features
PAL/NTSC-compatible
Tel. Mute
auto antenna control
http://gickr.com/results4/anim_5055e...a2b3b197c9.gif
1990 RHD JDM 300ZX TT 2+2 5sp T-Top
491RWHP / 18psi / 94 octane
Do a search on "where is Armen". In fact, there is a FAQ about it.
Michael
