I did my backlight with led's, & got the results I wanted & am happy with the backlight.... i looked into doing hundreds of small ones, as well as fewer large ones, & I don't remember all of my results, but I did come to the conclusion I would have more light going with larger 1 watt led's....
what I can tell you from experience playing with this though, is just putting an array like that behind an lcd will probably be very hotspotty... & you will need to add diffusion, which while helping the dispersion also cuts down on the final amount of light transmitted through the lcd.... a super bright light is needed, because you loose a huge percent of the light through diffusion & the lcd panel itself....
the way I did mine I wouldn't necissarily recomend to anyone, not because it isn't very effective, it is... but it's no where near the most efficient way of doing it, in cost & heat issues, not to mention the monstrosity it turned out to be.... no problem in my install, but not for the masses for sure....
from what I remember the heat issue will be there if your making as much light as you need to..... I wouldn't know, if you could get enough small super bright led's back there, how much of a heat issue you'd have.... from all of the research I did I don't think an array of just normal bright led's back there will be enough light.... & I think theres no way you'll have any hope of keeping an original housing.... you will need depth for this.
I think it would be cool for someone to try this.... if I do another one I will probably do it again with larger 1 watt led's, but this time attempt air cooled instead of liquid...., which is what I resorted to on my first one.... it get's hot..... real hot..... I wonder if that much light can be made with led's without the heat....
larger led's will need even more depth, & in playing with this I learned also that the dispersion improves as you back the led's away from the lcd... I think you need a lot of depth to get it to work good really... if you had an inch or so between that array & the lcd you'll need less difusion, which means more available light....
dimming leds is not a big issue, & will be the least of your problems...
LinkBack URL
About LinkBacks
