Page 4 of 11 FirstFirst 1234567891011 LastLast
Results 31 to 40 of 101
Thread: LED Backlight for LCD
  1. #31
    Oct 2004
    NY
    I originally thought of using hid... but heat was a major concern & heating the air is harder to disapate... you don't want air circulating through your lcd because of dust & stuff
    color temperature also makes a big difference, & will be a big problem with just any old light source... there are differences & white is not just white.. the xenon bulbs are good because you can get different color temperatures... the closest to my screen was like a 5.3k... they range from the 4k range (still kind of yellow) all the way up to & over 12k, which is so blue it almost looks purple..
    if you can't get a rating on the color temperature you should avoid attempting to use it as a backlight, because the wrong color light will make it impossible to get a good looking screen....
  2. #32
    Oct 2004
    NY
    & again, what seems bright may not be bright enough when behind an lcd... you need an extreme amount of light for this to have decent results....
  3. #33
    FLAC is for flaccid parksgm's Avatar
    Dec 2005
    Dallas, Texas
    Quote Originally Posted by turbocad6
    You mention valid concerns...dust, heat, and color temperature...but all solvable (and fairly cheaply, I would think) with good forethought and research before execution. Seems easier to address those concerns with a more mainstream, off the shelf solution if I have adequate space than try to rig a solution with underdeveloped/expensive technologies. After all, smaller usually = more expensive, at least initially.
    My point is that the limitation that people are trying to work around with a thin (and expensive) solution is mainly space behind the LCD...and if there is adequate space for another, cheaper solution, then why not go for it?
    Thanks for the concerns you listed...always good to have multiple troubleshooters!
    ...so, now I'll stop hijacking this thread and start a new thread if I decide to persue this avenue.
  4. #34
    lez
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    UK
    If you have the space behind for a big assembly how about a square funnel with a domestic bulb in it
    What about a 11 watt energy efficiant bulb, the flourescent type, and running it from a 12v ballast/inverter
    IE http://www.maplin.co.uk/images/Full/46289i0.jpg
    I think you can get this shape now in 12v in some countrys.
    Anyhow for a mains 110/220 just take the tube off, and connect it to the gubbins from one of these
    http://www.newenglandsolar.com/image...(Dscn0102).JPG
    So you have a round white light, I think an 11w tube is about 50w of light?
    how bright would an lcd be with the power of 50w (headlight?) behind it?
    Lez, more widely known as flez1966
  5. #35
    CarFrontEnd Creator iamgnat's Avatar
    Jul 2004
    NoVA
    Quote Originally Posted by parksgm
    High power incandecent bulbs that have color temp ratings aren't exactly cheap. The other issue with them is that the color temp degrades (relatively quickly, ~4 hours) as they are used.
    Tungsten bulbs don't have the degredation issue over their life, but they produce far more heat and are substancially more expensive.
    The upside of a LED or **FL backlight is that you don't need ready access to it as they have long lifespans. "Normal" blubs will most likely need to be replaced more often.
    -dave
    My pathetic worklog.
    CarFrontEnd (now it's own sub-forum!!!!)
  6. #36
    Dec 2005
    Dallas, Texas
    Quote Originally Posted by iamgnat
    -dave
    Some how I doubt that the color temp degrades that quickly...otherwise they really wouldn't be that useful for any applications. Do you have any data to backup that assertion?
    In any case, determining the amount of light needed is a simple physics equation or two away...light decreases in intesity with the square of the distance from the source (as I remember). As I see it, this has two important implications...
    1) The futher behind the screen the light source is, the brighter it must be...
    2) The futher away from the screen your eyes are, the brighter the light source must be...I guess that's something to consider when choosing a screen size and mounting location.
    What I don't readily know (but will work on) is how to convert light output in watts to a brightness equivalent in "nits". A formula that allowed conversion from one to the other would be useful for determining the amount of illumination necessary for the screen to be sunlight readable. As I remember, sunlight readable screens are generally >1000 nits, while the typical LCD display (like those sold on mp3car.com) are in the 300-500 nit range.
    I'm going to head to the ole physics book to do some research on this tomorrow.
    EDIT
    Found some info:
    http://www.marktechopto.com/Engineer...easurement.cfm
    http://www.reefkeeping.com/issues/2006-04/sj/index.php
    http://www.du.edu/~jcalvert/optics/lumens.htm
    LUMINANCE:
    1 lm/m2/sr (lumens per sq. meter per steradian)
    = 1 candela/m2 (cd/m2)
    = 1 nit
    = 10-4 stilb (sb) (or 1 candela/cm2)
    = 9.290 x 10-2 cd/ft2
    = π apostilbs (asb)
    = π x 10-4 lamberts (L)
    = 2.919 x 10-1 foot-lamberts (fL)
  7. #37
    Oct 2004
    NY
    the nit brightness is a mesurement of light through the panel.... every panel will be different & it will even be different in different spots on a given lcd... the brightness rating is an average of different points of the lcd
    regular consumable bulbs could be a pain, but again, we need EXTREME BRIGHTNESS... like a good projector bulb(expensive & hot... color?) a xenon bulb/hid (expensive & hot) or whatever else is extremely bright.... you loose like 90% of the available light to the panel alone.... that's extreme..... I did all my research a year ago, so my numbers could be a little off from memory, but I think it was between 85%-95%...... that's a lot of loss..... to make the amount of light you'll need will bring heat..... a lot of light will be a lot of heat
    I choose my led's specifically because all the heat they generate is disapated through the aluminum mounting pad, which gives me a way to extract & remove the heat..... a lot of high bright screens in kiosks & stuff use fans....
  8. #38
    Dec 2005
    Dallas, Texas
    No way there's 85 to 90% loss. Here's why:
    A typical screen consumes about 10 watts (or 1amp at 12volts)...that's to run the electronics and the backlight. If you take the electronics out of the equation AND assume that the backlight is 100% efficient, then there can only be 10 watts of illumination produced by the backlight. Period, 'cause Energy in = energy out - conversion to some other form.
    If the touchscreen blocked 90-95% of that light, then you would be left with a measly 1 watt or so of illumination, which would be dim even in a dark room. So, the touchsceen simply cannot block that much light.
    Maybe those figures are a bit more fuzzy then you think ;-)
    Of course, the upside of the above is that since <10 watts of illumination provides ALMOST enought brightness, then a relatively modest 50 watts at the light source should be VERY bright indeed.
    Another point to consider is that one either needs an EXTREMELY BRIGHT (your emphasis) point light source that is well diffused, or a somewhat less than extremely bright light source that is more evenly diffused from the beginning...like compact flourescent bulbs.
    Finally, the heat produced by the assembly will be function of two things:
    1) The efficiency of the light source
    2) The light absorbance of the screen...the more light the screen blocks, the more energy it will absorb (in both the visible and non-visible spectrums), and the hotter it will get.
    I think issue #2 is the most concerning, as it has the most potential to damage the LCD in the sort of setup I envision, with significant space between the light source and the LCD. In your setup, the LEDs sound like they touch (or almost touch) the screen, necessitating that the entire assembly be cooled. I don't have to care if my light source gets hot as long as it doesn't cause the light source itself to fail.
    Finally, I found this thread: Backlight using compact fluros and a ligtbox?
  9. #39
    Oct 2004
    NY
    im not saying the touchscreen, but the lcd itself....
  10. #40
    Oct 2004
    NY
    only 5-10% of what you start with will remain by the time the light makes it to the front of the lcd.... I did this, I have a workingf high brite screen in my car & I did tons of research, check here for a pdf discribing some aspects of lcd's
    trust me, you need an extreme amount of light to get any sort of decent results
  1. Replies: 21
    Last Post: 05-03-2006, 12:28 PM
  2. Backlight upgrade, using Extra CCFLs.
    By Fusion-One in forum LCD/Display
    Last Post: 03-28-2006, 08:42 PM
  3. LCD Backlight Upgrade
    By jcdillin in forum LCD/Display
    Last Post: 10-09-2005, 01:01 AM
  4. Red LED compass and/or thermo
    By WxGuy1 in forum Hardware Development
    Last Post: 08-06-2005, 01:26 PM
  5. Replies: 4
    Last Post: 01-03-2005, 02:36 PM
