Page 7 of 11 FirstFirst 1234567891011 LastLast
Results 61 to 70 of 101
Thread: LED Backlight for LCD
  1. #61
    Maximum Bitrate Sidewalksalvage's Avatar
    Mar 2006
    NJ/RI
    Here is my amazing paint diagram for all of you who wanted to see roughly what i did with my dual CCFL set up.
    Brown 2010
  2. #62
    Oct 2004
    NY
    that is an awsome idea.... if someone had 2 liliputs & one was the donor, that could be a good way to go to like 600 nits or so with no hassles I think...
  3. #63
    Mar 2006
    NJ/RI
    yep exactly....MUCH cheaper than transreflective, more available and better tested than LED...my easy alternative.
    Brown 2010
  4. #64
    Oct 2004
    NY
    maybe stack 3.... problem is sourcing the donors, but guys are screwing there screens up al over & dumping them too... but your still ging to spend some bucks unless you already have a few busted lilli's laying around...
    ....thinking further, if you have a few busted lilli's laying around, you may not be the best type of guy to do this
  5. #65
    Mar 2006
    NJ/RI
    originally i was going to position both CCFL's on the single light guide, but the plugs on either end of the CCFL's prevented me from doing so.
    As for getting a doner...maybe search on ebay for a busted lilli or xenarc.
    Brown 2010
  6. #66
    Mar 2006
    NJ/RI
    HAHAHHAHHAHAH
    true THAT.
    The one i used was from the projector i made. the LCD no longer needed it since it had the 600 watt projector bulb as its backlight.
    the light guide i used was simply from another 7" LCD not even the same brand. and it still worked great
    Brown 2010
  7. #67
    Oct 2004
    NY
    I think you hit a real nice idea there... I wonder if larger lcd lightguides could be cut down... broken lcd's are a dime a dozen on ebay, but larger ones... you'd still have to source the light source though... having the same size donor screen makes this look real easy though...
  8. #68
    FLAC is for flaccid parksgm's Avatar
    Dec 2005
    Dallas, Texas
    Hmmm...so the answer to "I need more backlight" is "double the backlight".
    Brilliant. Literally.
    This does look promising...of course, I'll do some searching and find 10 people who will have tried it and found that it doesn't work. ;-)
  9. #69
    Mar 2006
    NJ/RI
    HAHAHAHAH id love to see if others had done it...
    I thought it was already widely done....I just figured that since in some bigger monitors they use more than one CCFL why not my 7"....
    Brown 2010
  10. #70
    Oct 2004
    NY
    I think it has to work... the key is the lightguide though, to allow even dispersion & 100% utilization of the add'l light
  1. Replies: 21
    Last Post: 05-03-2006, 12:28 PM
  2. Backlight upgrade, using Extra CCFLs.
    By Fusion-One in forum LCD/Display
    Last Post: 03-28-2006, 08:42 PM
  3. LCD Backlight Upgrade
    By jcdillin in forum LCD/Display
    Last Post: 10-09-2005, 01:01 AM
  4. Red LED compass and/or thermo
    By WxGuy1 in forum Hardware Development
    Last Post: 08-06-2005, 01:26 PM
  5. Replies: 4
    Last Post: 01-03-2005, 02:36 PM
