Page 8 of 24 FirstFirst 123456789101112131415161718 ... LastLast
Results 71 to 80 of 235
Thread: 7" Transflective monitor with T/S kit available now at the Mp3Car Store
  1. #71
    Maximum Bitrate Caelric's Avatar
    Sep 2005
    Bellevue, NE
    Yep, me too. As soon as one that fits the G35 enclosures comes out, I'll be number one in line. It's pricey, but it looks to be well worth it!
    Dave
    2005 Infiniti G35 6MT Coupe Black/Black
    Core Duo CarPC
    CarDomain page
  2. #72
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    Quote Originally Posted by Zip-Lock
    There are no off the shelf bezels that fits it correctly.
    Yes it should fit without modification.
    Is this a contradiction or do you not consider the mechatronix bezel to be off-the-shelf?
  3. #73
    Aug 1999
    Washington D.C.
    Quote Originally Posted by rando
    I didn't consider it to be off the shelf because it only applies to those to have Subaru's
  4. #74
    Variable Bitrate nameeri's Avatar
    Mar 2006
    SoCal
    Quote Originally Posted by kickercivic1
    would this kit fit right in the xenarc case with out any mod???
    Yes this will fit into a Xenarc bezel. thats what im using. You will need to put some double sided tape around the very edge of the TS before mounting into the bezel so the edges of the TS are not compressed.
    Civiputer: Dont have one anymore, but here is what is used to be!
  5. #75
    Aug 1999
    Washington D.C.
    This just in: Matt from mp3car tech support just figured out a way to get the monitor to go back together in it's bezel without causing the touchscreen to go crazy. Apparently the secret is to not tighten the screws holding the LCD panel down too tightly. Having them too tight makes the touch panel always think that it is being pressed and causes the curser always move the edge of the screen.
    We’ll be offering an assembled version of the monitor immediately, just put in your order comments that you request that the monitor be assembled and we’ll do it for no additional charge.
  6. #76
    Jun 2005
    Davis, CA
    Doh! Too bad mine's already in the mail. :-) Is it pretty straightforward to assemble it the way you described? Are there any simple instructions included with the kit? Any chance you could provide some pics if it's not a straightforward process? ;-o
  7. #77
    Jun 2006
    München / Germany
    Whats about a 7" VGA transflective (sunlight readable) monitor w/o touchscreen?
    I dont need the touchscreenfuncionality
    And I think, the display will be much brighter w/o ts.
    Es kann nur einen geben...
  8. #78
    _
    Mar 2004
    Little Elm, Texas
    you can buy a screen without the touch screen in the store right now. They are usually brighter because they don't have the touch screen over lay on them.
    Jan Bennett
  9. #79
    Aug 1999
    Birmingham, Alabama (War Eagle!)
    zip-lock you rock! i'll be ordering mine on next payday.
    look forward to it.
    thanks.
  10. #80
    Low Bitrate baudi's Avatar
    Feb 2006
    Arlington, VA
    Is there any difference between this screen and the liliput screen in terms of the ability of windows to drive it at 800x480? This seems to be an unsolved problem.
  1. Anyone else have poor customer service from MP3Car store?
    By DustPuppy in forum General MP3Car Discussion
    Last Post: 09-07-2010, 11:21 AM
  2. How much have you spent at mp3car store?
    By nappyjim in forum General MP3Car Discussion
    Last Post: 06-16-2005, 08:58 AM
  3. Question about mp3Car Store
    By DigitalAce7 in forum Newbie
    Last Post: 04-30-2005, 10:43 AM
  4. Australia MP3CAR Store
    By Fox_Mulder in forum General MP3Car Discussion
    Last Post: 11-09-2004, 10:29 AM
  5. mp3car store to australia
    By dogah in forum Off Topic
    Last Post: 09-13-2004, 09:05 PM
