Absolutely! You can certainly hack the PSOne LCD for use with your computer. Probably the most helpful and well-known site for the hack can be found at BitTech .
It's a smaller screen but it does have a great picture to it.
Can I connect the PSOne LCD to my computer. If yes the please tell me how to do it.
thanks
$0|-|@i8
Just search for PSOne Mod on this forum and you are good to go. If it return too many result, narrow it down to either users startfox, mpro and hell yeah ... me too.Originally Posted by sohaibma
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
another good resource: http://starfox.ucc.asn.au/carcomp/data/PSOneLCD.pdf
Jan Bennett
ooooh, brings back memories
ooooh, and they're good memories of cheap ( got two of mine for ~ $40 at Best Buy) and sunlight readable (ok, maybe not in a convertible in Texas in the summer).
- Monthly North Texas Meet thread
- My worklog
- gDrive Install pics
- How to add your CarPC specs to your username
An amateur built the Ark. The Titanic was built by professionals.
How about http://tidder.rudyatek.com/lcd/
Good hardware side of the mod. And by no other than myself. Yay.
EDIT: Uh-oh, it's down again... what a sad day it is.
EDIT #2: Moved it to my site. Link is now http://www.dynamic-i.com/lcd/
EDIT #3: The only thing I'm missing that I should add are VGA pinout pics and stuff. That would be good. Anybody have anything to offer me?![]()
hi, it mentions a secondary video card - why does it need a secondary video card please?
Well, one reason is that unless your primary card has a dual output, it's going to be difficult to test if your modificaitions to the PSOne work without unplugging your primary monitor and plugging in the modded PSOne.Originally Posted by dave bev
But the real reason is that the modded PSOne requires a video card that allows one to make several adjustments to the output signal that many video card drivers do not support/card doesn't allow. I'm not sure of the specfics, but it has to do with composite sync, whatever that means. If you read the various how-to threads, you'll find that each modded PSOne requires some specific fine-tuning of the video card settings...settings that work for one person often don't work for the next.
Hope that helps...
- My worklog
I also started this mode and i have 3 Questions:
1.riva tnt will do or only with ttl circuit?
2.can i flash the setting to the vga card chip so i can also boot from the psone lcd?
3.I have a vga cable and every cable is in a diffrent color, is there anyone that find a diagram for what every color is?
I understand that the ones that really can help in this mode are starfox,mpro,tidder,masterpc.
i will really apriciate the help...
