To get magenta you mix red and blue. Since anything that should show white is showing magenta in your image, that means the green channel is off.
I would suggest re-soldering all of your connections. Maybe you have a dry joint somewhere (i.e. looks like it is soldered, but isn't really). Given it runs off 12V you can open it up while switched on and poke around.
My in-dash screen recently did something similar. The flexible ribbon cable that connects the screen to the board inside the fixed part of the unit was not properly located. I had only the blue channel at one point. Relocated the cable and that fixed it.
LinkBack URL
About LinkBacks
