Results 1 to 4 of 4
Thread: Huge Problem: LCDs won't work with Lilliput and M10000
    Oct 2005
    London, Ontario
    Hello,
    I just installed my two headrest monitors and am having a huge problem trying to get them to work.
    They are connected to the composite video out on the m10000 motherboard. whenever i attempt to enable the video out i get a "OVER RANGE" message on the lillliput. I was told to set the bios to CRT+LCD on the 1.16 bios. That still doesn't work... The screen just went distorted this time. (Note: Ive tried every setting in the bios now)
    I even tried switching the bios back to the 1.13 version and it still doesn't work at every bios setting!
    Could someone please try and help me with this!!!!
    Thanks,
    slevytam
    Oct 2005
    London, Ontario
    I just wanted to add that if I set the motherboard to CRT+TV the lilliput just goes white and the lcds work fine!
    Banned JagPuter's Avatar
    Apr 2006
    My Garage
    Set it to use both... if you can. If you can't do that. Refer to your manual. If you can't do that. It can't be done.
    Mar 2006
    Colorado, but Canadian!
    Well, from the headreast monitors, with the lilliput still plugged in and white, go to display properties, and see which monitor is the primary, and what the resolutions are on both. I would set the primary to lilliput and the extended desktop to the headrest monitors.
    1.9in x 2.9in -- 47mm x 73mm
  1. Lilliput Touchscreen Driver Problem.
    By gleinz in forum LCD/Display
    Last Post: 01-12-2007, 12:30 AM
  2. Lilliput Touchscreen problem
    By DookieGraphics in forum LCD/Display
    Last Post: 03-24-2005, 03:33 AM
  3. 7" Lilliput NON-touchscreen and VIA EPIA M10000 questions
    By 98EXL in forum General Hardware Discussion
    Last Post: 03-16-2005, 10:52 PM
  4. FS: M10000 Lilliput Slot Load DVD 60G HD
    By heefer12 in forum Classified Archive
    Last Post: 02-13-2005, 03:25 PM
  5. WTS: Opus 90w, EPIA M10000 (new refurb), Lilliput 8" screen
    By therussman2002 in forum Classified Archive
    Last Post: 01-12-2005, 01:01 AM
