Bump!
Hi Everyone,
Been reading on your forum here for a while, figured you guys would know the short answer to this question:
Can you mount a Lilliput 639GL 7" Widescreen in a 2-DIN dash? I assume the dimensions of this would be about 179W x 100H x 190D. Width and height is what I am most concerned over (obviously!).
Some details I have found on the screen show the dimensions being 185mm Wide x 128mm High. What I need to know is, is this including the fascia of the very front of the screen, or does that extend further than 185 and 128mm? Check this pic for a reference: http://www.ex-audio.com/ebay%20pictu..._new_side2.jpg
Also this pic: http://www.ex-audio.com/Inventory/US..._touch_new.jpg
So long story short, could you get this screen to jam into a 2-DIN dash with a little cut-and-shut, or would it be a messy task?
Any info would be great. Thanks a lot.
Cheers,
Scoota
Bump!
You're going to be doing a bit of fabrication work. How much fabrication depends on your vehicle's dash and how you want it to look when you're done.
There's a thread in teh FAQ Emporium named "Everything you want to know about your Lilliput". I suggest searching it out and reading it, as well as any other threads in the FAQ Emporium. You can't have too much knowledge.
