Hey guys hope you can help. I bought the DWW-7VGA from digitalww.com hoping that it would fit right into the factory DVD/Mp3 player slot in my Acura TSX. Well with the case it was too big by a couple of millimeters so I had to break it apart and mount the components to the factory housing. All was going fine I had everything mounted up so I decided to power it up using a wall outlet power brick I had used many times before. Again everything worked fine then I walked away from it for a bit, while it was still on. When I came back the screen was off and the standby light was off. I checked and it was still plugged in. I then looked at the power brick and it had melted slightly. So I replaced the power brick and still nothing. I pulled everything apart and went over it with a multimeter and its getting power just not turning on. I didn't smell any smoke or see fried components. I'm I screwed here or what?
