Results 1 to 10 of 15
Thread: TV out EP 13000 HUGE PROBLEM non noob
    Variable Bitrate Philhop's Avatar
    Apr 2006
    Question TV out EP 13000 HUGE PROBLEM non noob
    Hi , all I have a huge problem that has been bugging me for ages cant get my 3 lcds via rca going my vga goes fine every setting i try results in a black screen on the head rest monitors , if i try crt - tv both vga and tvs go black no picture. Have tryed windows settings and 75 ohm resistor on the rca cable .. Any suggestions This is driving me up the wall.
    Apr 2006
    Have also tryed Svideo port same problem , tryed almost everything and anything bios updates even went back to the old bios
    Mar 2006
    Colorado, but Canadian!
    It sounds like a simple power problem. It isn't there. You are just splitting the cable 3 ways? Or vga out of mobo to touchscreen and rca out of mobo and then split the rca to both headrests?
    Either way, my first suggestion is that you try an amplified video splitter. That way you aren't just splicing wires, your keeping the power the same but making 2 cables.
    1.9in x 2.9in -- 47mm x 73mm
    Apr 2006
    vga out of mobo to touchscreen and rca out of mobo and then split the rca to both headrests yes im using a 3 way splitter hmm i could try that the thing is it worked with my xbox
    Apr 2006
    Also one screen by itself doesnt work as a note.
    FLAC sama's Avatar
    Feb 2006
    London, UK
    I assume you have the right drivers for everything. if your xbox works and 1 video out doesn't, sounds to me like the problem is either carptuer hardware/software related. I'm not familiar with your mobo, but these are things I haev to do on mine:
    check all your bios settings to ensure video out is configured. it may be off
    check any jumpers on the mobo that might enable/disable video out
    ensure that the dual output settings of your display settings are set to clone
    other than that I'm not sure what else can be wrong, it may be a faulty board.
    Maximum Bitrate DeltaFX's Avatar
    France
    Looks like the Epia can't have both VGA & RCA at the same time.
    Now Galileo is real. Muhahahahaha :p
    Constant Bitrate Eternalodyssey's Avatar
    Oct 2005
    St. Louis, MO
    The VIA SP 13000 supports both VGA and RCA out at the same time. Make sure that your pins are set correctly. if you are running three RCA-fed screens off of one output on your motherboard, you are going to need a video amplifier, trust me. There is not enough signal power to drive all three. There should be documentation that came with your Via Mobo that explains how to enable video out. or you could the Mobo and find the PDF file that way. But it is not hard to check the pin settings to enable video out. Mine did not come factory set to do video out. Good luck.
    Check out the updates. Project 2003 Dakota worklog: http://www.mp3car.com/vbulletin/worklogs/85490-project-2003-dodge-dakota.html
    IS JACK BAUER GONNA HAVE TO SMACK A *****?
    Mar 2006
    I don't know about pin jumpering to get different video. On my older M10k, it is part of the BIOS. You cna choose between CRT, LCD, and TV and any combination of the three. That's how you enable the different ports to function. I do indeed agree with the video amplifier though, you need one. You can get them relatively cheap, especially on eBay!
    Apr 2006
    I disagree with all the posts im sorry. After a huge malifunction tonight I re looked checked every jumper on the motherboard the on on the LVDS I think was broken, I replaced this and farted twice and burped , then usure on what the outcome was ,
    1. Powered up to windows.
    2. Set it from CRT - LCD to CRT and PAL boom worked was black and white so I set to NTSC
    3. Realising now it wasnt saving my settings i tryed it in the bios
    For some reason now its working flawlessly with no amps ect. I guess this posted helped me and i beg others with problems to check the jumper on lvds to make sure its correct , unsure on what this jumper does but it did the trick but im not 100% because I was tweeking alot of things at one time, Carput is now at 90% waiting for my 100 gig to come back from RMA. Ill show of my project soon , Im very impressed with my work, many thanks to all that have helped, and answering my questions.
  1. Problem with TV Out not recognizing LCD
    By Hiphophead in forum LCD/Display
    Last Post: 01-01-2004, 04:42 AM
  2. 5" LCD Screen TV Antenna Problem
    By owenjh in forum General Hardware Discussion
    Last Post: 12-16-2003, 04:15 PM
  3. Epia 9000 Problem w/ TV Out
    By blazinlow in forum General Hardware Discussion
    Last Post: 03-05-2003, 12:15 PM
  4. TV Tuner Problem!!!!!
    By FreznoSmooth in forum General Hardware Discussion
    Last Post: 08-15-2001, 10:19 AM
  5. Problem with Jaton video 77 w/ TV out
    By Dustin Haug in forum Software & Software Development
    Last Post: 04-21-2001, 08:58 AM
