Results 1 to 8 of 8
Thread: allen's controller question
    May 2000
    Ft Gordon, GA
    im using allen ruble's controller with my 8.4 in tft. all of the controlls work on the controller except "H pos" anybody got any ideas why this is? also if i wanted to hook my inverter through the card which pins would hook to what? (right now i am stealing 5v from the comps psu). thanks,
    etrik
    "if everything is under control, you're not going fast enough!"
    Jan 2002
    Florida
    As for the BL (backlight) inverter part, I don't think anyone around here knows exactly how that works. There is a thread in the LCD section that has been revived, Info on Allens TFT To VGA Converter , and does have a little info on the pins.
    Let me know if you find anything.
    System in the works:
    Celeron 850 or PIII 933, SB Live! Value into a stock 4 channel amp, ATI vid, 10.4" sharp LCD w/ allen's controller, Elo SW touchscreen overlay and controller, GPS, TV tuner, FW DVD drive, 4 port serial card, and some other stuff....
    Loads of ideas.
    Nov 1999
    Sydney NSW Australia
    Its simple really...
    THere are 5 pins.
    two 5v (even though one is around 4.6v)
    one 10v
    one ground
    and one control
    I got it working with my LQ9D023 screen that came with the standard backlight inverter.
    however the inverter need somthing like 6-7v to operate.
    I tried using the 5v rail but it was too bark tried the 10v rail and nearly burned the inverter...
    around 7 volt makes it perfect.
    I can adjust the brightness and everything...
    Fosgate
    System Comp V3 - In progress.
    Low power MB with C7 CPU, DC-DC PSU, car ECU link, USB TV, GPS, 7" TFT, Wireless, Voice.
    Variable Bitrate Cyberphox's Avatar
    Sep 1999
    New Glasgow, Nova Scotia, Canada
    Even simpler..I want one of Allen's controllers...sell it to me and solve all your headaches
    Jan 2002
    Florida
    Not bad. Do you know if that is the order of the pins as well?
    Loads of ideas.
    FLAC mp3z24's Avatar
    Apr 2001
    Chicago Suburbs
    THere are 5 pins.
    one 10v
    one ground
    and one control
    alright... then kindly share what pins are what values
    i know a couplse of people that would love to have that info.... myself included!
    ~mike
    Single Member of the "1000 Post and No MP3 Car" Club
    PROJECT ON INDEFINATE HOLD... BOUGHT A HOUSE
    2000 Cavalier Z24 [###-------] Only 30% Done ... Still
    Dec 2001
    usa
    MP3Z24 is correct.
    I would also like that info please.
    Thanks,
    pigseye
    Nov 1999
    I sure can ...
    From memory its goes like this
    ======= Edit =======
    Pins:
    1 GND
    2 10V
    3 4.96v (5v)
    4 Control
    5 4.47v
    Looking from the PCD (non component side).
    THis is from the memory, when i get home I'll have a look at the pin numbering and will let you know exactly.
    The control voltage goes from 0v to +5v
    Note: I found that the standard Inverter that comes with the LQ9D023/LQ9D02C doesn't work with any of those voltages. THe control is ok but the running voltage is not in the range.
    I suspect that the inverter requires around 6-7v to operate.
    The voltages from the controller are either too high 10v or too low 5V.
    Fosgate
